The small form factor of the Mini 0801 really appeals to me, but I have only seen pictures of it mounted where the long body is mounted horizontally (like in the following image)
However, I would find it to be a more appealing camera if I could mount the camera so the body is vertical and only the camera lens is peaking out from behind my mirror as opposed to the entire body of the camera (this would likely require a different mount obviously so I could still achieve up/down tilt).
My Question:
Is it possible to adjust the camera such that it can be mounted "vertically" as I mentioned previously while still capturing the same information as it would when mounted "horizontally" (i.e. still record such that the longest portion of the aspect ratio records what is happening more of what is happening to the left and right of the vehicle rather than up and down--while the sky is nice to look at, I am not to interested in recording more of it than I do objects at ground level with my camera)?
Thank you in advance for your responses!
My Question:
