I'm not sure that is correct. I always thought the default is buttons up. Both the app and mSetup use a single toggle to control 2 settings in the FW for image orientation. Could be that you found a bug.Default orientation is buttons down.
Yes. There is some inconsistency between the app, mSetup and the FW settings:No bug, changing orientation using the app works fine. And yes, buttons up is default, got confused.
Seeing more than just Upright and Inverted. No 'Auto' in the app yet.
Do you like the Maxi as a discreet rear camera? I currently have a Mobius 1 rear camera that I'm considering replacing with a Maxi.F.W V. 2.26 - 1080p, 30fps. Bitrate - 24Mbit/s. Exposure Metering - Centre-Weighted, Video Quality - Extreme Fine, Volume - Medium.
Night - Rear
Hopefully that is something Mobius can fix through FWImage darkening due to bright spots still happens with 2.26. Helps sometimes with plate capture but at times it gets a little too dark.
Didn't anyone notice the drop in sharpness at 0:22 and 1:32?
I agree that the Low (and High) light priority settings are too strong for regular use. Multi Spot and Centre Weighted seem best when used as a dashcam.Never mind, I'll stick to Centre-Weighted.
