RobTrehy
- Jan 9, 2017
- United Kingdom
- VIOFO A119
After recently purchasing an A119 I wanted to be able to extract the GPS data from the MP4 files.
I used SergeiF's script initially, but I'm not able to install Python on my work computer, so wanted an alternative.
I am not a professional programmer, but I like to challenge myself.
After a few failed attempts, I had a native Windows application to perform the same action.
You can find further information at my blog post HERE
Or some basic information here;
Compatible with A119 Firmware version 2.0
You require .NET Framework 4.5.2
It has been tested on Windows 7 (64-bit) and Windows 10 (64-bit)
Version 2.4 - Release: 30/03/2017
- General bug fixes
PLEASE NOTE: Using with version 1.1. firmware in this version will pull the day of the month from the file name. To use NovaTrakt successfully, please only use the original filenames.
This method was chosen as to not delay the release of version 2.3, so that users with 2.02 firmware can use NovaTrakt.
It has been brought to my attention that NovaTrakt is compatible with VIOFO A119S running version 1.0.1 firmware, and suspect NovaTrakt 2.3 is compatible with A119S running version 1.2 firmware. I do not own an A119S so am unable to test this.
Please Note: There is a bug in version 2.01 firmware preventing NovaTrakt from working with it.
You can download the latest standalone EXE file HERE
If you use the application, please consider donating HERE - If you are unable to use the link, please PM for alternative methods
Previous Versions:
Version 1.0 - Release 10/01/2017
- Initial Release
Version 2.0 - Release: 20/01/2017
- Input file changed to Input directory
- All code rewritten to improve speed during processing
- Improved logging (stored in NovaTrakt.log file alongside executable)
- Improved general reliability
Version 2.1 - Release: 21/01/2017
- Bug Fixes
Version 2.1.1 - Release: 22/01/2017
- Bug Fix for Coordinates with no decimal point
Version 2.2 - Release: 17/02/2017
- General bug fixes
- Bug fixes for alternate regional settings
- Fixed bug that caused GPX files to contain the previous videos GPS data too
- Improved logging
- Logic improved to speed up processing
Version 2.3 - Release: 03/03/2017
- General bug fixes
- Compatible with A119 new version 2.02 firmware
- Compatible with A119 version 1.1 firmware
Donors:
@Mtz
@viofo
@BCHobbyist
If you do not wish to appear on this list, please let me know.
Thank you!
In future versions, I would like to add;
- General bug fixes
Previous Versions:
- Initial Release
- Bug Fixes
- General bug fixes
- Improved logging
- General bug fixes
Donors:
@Mtz
@viofo
@BCHobbyist
Thank you!
- Use an input folder, so multiple files can be used at once (DONE)
- Continuous single output or multiple file output option
- CSV output option
- Plus more (let me know your ideas below!)
