PAL/NTSC is for the AV output, 50/60Hz is the refresh rate to avoid flicker in the video from incandescent lighting, setting the refresh rate to 50Hz while running 30fps can be problematic so some developers change the frame rate to 25fps when using this mode to avoid problems
