Panorama S FIRMWARE UPDATE Request Thread (Do Not Flash New 2015 S Units with OLD 2014 firmware!)
Street Guardian USA
Retailer
Oakland Park, Florida (USA)
StreetGuardian.CAM Amazon.com
AS OF 2015, all newly shipped Panorama S cameras will have new IMX322 sensors and tweaked hardware and cannot be downgraded to the older 2014 firmwares previously listed on the main Panorama page:
https://dashcamtalk.com/powerucc-panoramaii/#Latest_Firmware
This applies to Panorama S with serial numbers starting with PF140400
PLEASE DO NOT ATTEMPT TO FLASH new 2015 Panorama S models with older 2014 firmware
(You will Brick your DashCam)
If you bought your Panorama S from Pier28 please send me a PM. If you bought it from anyone else, please contact your seller for the proper firmware and to confirm you get the right one.
Previous older firmware:
  • GLG300_V1_12_06_20140421_12Mbps_Intl.zip
  • GLG300_V1_12_06_20140421_15Mbps_Intl.zip
  • GLG300_V1_12_06_20140421_18Mbps_Intl.zip
Previous Firmware Versions
  • 1.06.10
  • 1.07.00
  • 1.07.05
  • v1.08.03
  • v1.08.05
  • v1.09.03 (Beta)
  • v.1.10.04 (Beta)
  • v1.11.03 (Beta)
  • v1.12.02
  • v1.12.03 (same as v1.12.04 but with blue LED off)
  • v1.12.04 (same as v1.12.03 but with blue LED on)
  • GLG300 v1.12.03 21Mbps.zip
  • GLG300 v1.12.03 15Mbps.zip
  • GLG300 v1.12.03 12Mbps.zip
EDIT: 26APRIL2015
Due to the fact there is risk of bricking your dashcam, you should ask your place of purchase for the correct firmware. If anyone is an authorized Panorama seller they will have the correct firmware and be able to support you no problem.
Examples:
USA Authorized Seller: @Pier28
UK/EU Authorized Seller: @niko
There maybe be a few others & I can edit this list as needed.
hello
I have an old Panorama II (non S) version. The original firmware was 1.08.03.
However after I flashed it to 1.12.06, the motion detect is no longer working. It will record every minute through out the night even though motion detect is turned ON.
Can anyone pls kindly send me the firmware version 1.08.03?
Hopefully the motion detect can work again after resuming to original firmware.
Is the downgrade brick a result of changes made by the firmware or of a slight change in hardware in the newest models?
In other words, if I have an older unit and upgrade to newer firmware, would I be able to then downgrade back to the older firmware again or would that still cause a brick situation? Or is the newer firmware incompatible with the older units--and if so, will the older units still receive firmware updates?
Minor hardware change, so new units will ship with a special firmware. Quality and features are identical. There is one firmware available for the new units.
Original S, pre-Dec can use any firmware listed in the original post.
Update:
I just confirmed with SungMoon that all 2015 Panorama S, G, and X2 all now have the Sony IMG322 Sensor. (X2 always had it of course)
The performance is pretty close on both sensors.
- It's very important that 2015 Panorama S/G units should never install any older/prior 2014 firmwares.
(this is why we don't post firmware's public any more, and give case by case via private message/email)
- Prior 2013/2014 IMX122 based Panorama S/G units can use 2015 firmware though no problem.
We will elaborate on this soon. (and adjust the original post)
The latest firmware that is compatible on all 2013/2014/2015 Panorama II/S units is v1.15.01 20141224 1430 (15Mbps)
(added native exFAT formatting inside the camera support for large cards up to 512GB
as firmware v1.15.01 is compatible with all cams any chance you could post it. if not pm me a copy please
Could someone please send me the link for the firmware for the pre-December IIs which Jokiin mentioned just came out a few days ago, and allows narrowing the field of view?
Thank you!
Since the purchase of my panorama S it cannot read my Kingston 128 GB Class 10 UHS-I SDHC/SDXC card. I already verified the write/read speed and I have a genuine card. On startup it gives a "Card error", formatting is not possible. Also formatting on my PC with the suggested tool isn't helping. A 16 GB SD cards seem to work fine.
The dashcam has stock firmware version:
GLG300 firmware 1.12.06
2014-04-22 18:00
What firmware do I need to get my dashcam to read this SD card?
Thanks in advance.
2014-04-22 18:00
Thanks in advance.
You need the latest 1.15.01
I'll send a PM now check your inbox
2014-04-22 18:00
Thanks in advance.
once you have the new firmware format the card in the PC back to default exFAT settings and then format in the camera, you'll need a smaller card to install the update obviously as you won't be able to read the firmware from that card until after you've updated
@Pier28
Please send PM with latest firmware.
Thanks!
Purchased via Amazon from Piers28 stock, late August, early September.
Dashcam has stock firmware version:
2014-04-22 18:00
@Pier28
Thanks!
2014-04-22 18:00
No problem coming right up, I thought you only had the G. You're double Pano-ing.
