- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
@NZDashcam I like to keep the G-Sensor set to high for parking mode and low for driving mode.
I confirmed 11.8 voltage will cause problems. Only use 12.4 at this time. It will cut closer to 12.1 after the loss.
I've got to admit I've been using 12.1V mate but as they're saying it could be causing the random lockups I'm going to up it to 12.4V while Sungmoon fixes the codeWhat voltage setting should I use for parking mode? I have it set to off at the moment, but my auto electrician said I don't need to worry as it's a brand new car and the battery should be able to handle it. @reverend, you're probably best suited to answer this one as you live not too far from me I believe
1.02.02 Beta just arrived to fix the Beep On/Off settings to Obey.
(minor change/update so we can fast track this one)
I get the message "not found firmware in rear card" I've swapped the cards (F&R) and get the same message.
I'm doubting myself now. Normal definitely has and I remember checking movement sensor, but I can't recall a definite shock only rear record while parked.Yes it has worked
