So, the good news is that the relayed works well with 5v sources. Switching goes well, but either the switch speed is no where near as fast as they claim, or the camera is not happy with the change in input voltage. Switching from ignition mode (5v3) to parking mode with the River 2 (5v0), the camera shuts down and then powers up again. This isn't as smooth and seamless as going in and out of parking mode on the same voltage level where the camera just announces that it's in parking mode or that two channels are recording.
But then the symptoms got worse. The camera isn't happy at all with different voltage levels when switching back and forth from ignition mode to parking mode. The 5v USB cigarette socket adapter that came with the Viofo puts out about 5v3 volts while the EcoFlow River 2 USB port provides exactly 5v00. Turns out that 0v3 difference is pretty important to the camera. If I run the camera from the River 2 USB at 5v00, the camera works fine. I can repeatedly make the camera switch in and out of parking mode by connecting the yellow wire to the red wire and removing it again. No power cycling, it works great. The same is true for using the Viofo USB adapter that provide 5v3. By touching and removing the yellow wire to the red wire, the camera goes in and of parking mode repeatedly, exactly as expected. Using both power supplies with the relay, though, the camera will handle the switch from 5v3 to 5v0 when it transitions from driving mode to parking mode, but only one time. Once the camera enters parking mode with a reduced input voltage (transition from 5v3 with the engine running to 5v0 from the River 2), it refuses to come OUT of parking mode. When I switch back to the 5v3 power supply that activates with the car's ignition, it just stays in parking mode. Nothing else happens until I do a full power down. Total bummer...
I also discovered another interesting behavior. The yellow wire doesn't seem to be just an input trigger for parking mode vs drive mode. It also carries a signal voltage out of the camera. When the camera is on and the yellow wire is not connected, it carries a 0v1 signal with respect to the black wire and a -4v7 with respect to the red wire while the camera is in parking mode. This voltage seems to cause some issue with the LEDs on the relay because it "crosses over" from the relay's output terminals to the input terminals.
My overall conclusion from the day is that I need to abandon my idea for running the whole system on 5v. This is rather disappointing.
I'm thinking I need to reattach the Viofo voltage regualtor to the power cord and switch to using a 12v wiring configuration. I wanted to use a 5v configuration because that's what the River 2 will provide automatically as soon as it powers up with the car. Using the River 2's 12v system requires manual intervention from me, which is not ideal, but workable.
So, it looks like there are two options:
1) use the 12 utility output on the River 2 and have to manually turn it on/off each time, or
2) use a 5v to 12v converter that will fit into the UBS port on the River 2 and connect the 12 into the Viofo voltage regulator.
Playing around with the Viofo voltage regulator and a bench power supply, I learned that the regulator provides a very consistent 5v26 output, pretty much regardless of the input voltage. The regulator IC they use in the little box seems to require very little headroom (about 0v15) which is pretty impressive coming from the context of discrete regulators that I'm more accustomed to using.
Any thoughts about the reliability or feasibility of the 5v to 12v converters? I'm not excited about adding another voltage converter into the power supply chain.
Sigh...
