Parking Cam cable - Dash 55
Discussion in 'Garmin' started by Holymonkey, Dec 3, 2017.
  1. Holymonkey
    Holymonkey New Member
    2
    Country:
    Hi,
    I’m looking to hook the parking cable up to the fuse box (appears to be the easiest source to connect too) but a bit flummoxed as to how to connect it up.
    I’ve brought a piggyback fuse connector but this only connects one cable & the 55 parking cable has two.. is the answer as simple as that I just need two piggyback fuse connectors or is there a better way of connecting the cable?
  2. jokiin
    jokiin Well-Known Member Manufacturer
    37,017
    18,933
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    Only the positive wire will be fused, the other wire goes to earth
  3. Holymonkey
    2
    Country:
    I should of been more specific! The 55 parking cable has 3 wires - earth, permanent supply and ignition supply - I’ve connected the earth to the chassis but now left with the other two wires to connect.
  4. jokiin
    37,017
    18,933
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    Then you'll need two fuse taps, one connected to a switched power source and one connected to a permanent power source
    SawMaster and Holymonkey like this.
  5. lacibaci
    lacibaci Well-Known Member
    933
    378
    Country:
Loading...
Share This Page
