Parking Guard Questions from a first timer
vben
Miami, FL
Mini 0906
Let me begin by stating I know close to nothing about wiring or installation. The Mini 0906 is my first dashcam and exited about using it.
I bought the mini 0906 and Veckle Parking Guard hardwire kit Parking mode https://goo.gl/PrAuGj for my 2013 Toyota 4runner.
I want to use the parking guard function and have a few questions.
1. Do I need 2 Add-a-circuit Fuse taps? One for the red wire (constant) and one for the yellow wire (accessory)?
2. Should I connect the red wire to 12 Volt and yellow to a 12 volt? (Is 12 volt the correct amps?)
2. Which fuse amp do I need for the dashcam? 5, 7.5, 10, 15, 20, or 30 Amps?
3. For the 2013 4Runner, what blade type fuse size do I need? Low-profile mini fuse, mini fuse, micro2 fuse, or regular fuse? https://en.wikipedia.org/wiki/Fuse_(automotive)
Also, helpful hints or installation / instructions website links? Thank you in advance for your help.
1. Do I need 2 Add-a-circuit Fuse taps? One for the red wire (constant) and one for the yellow wire (accessory)? ---- depends on version, (normal glass tube fuse version, or piggyback blade fuse version.
2. Should I connect the red wire to 12 Volt and yellow to a 12 volt? (Is 12 volt the correct amps?) ---- red to constant 12V and yellow to ACC 12V
2. Which fuse amp do I need for the dashcam? 5, 7.5, 10, 15, 20, or 30 Amps? ----- 2A or 3A is enough.
3. For the 2013 4Runner, what blade type fuse size do I need? ---- i am not sure. please check in your car, or consult with repair shop
