Thought I re-post this here.
I received VIOFO's reply today as below:
Without the HK3 hardwire kit, the camera will leave parking mode once it detects the GPS info that the speed is above 8km/h.
Then I did more tests here. But note the following first:
The v1.03 firmware available for download from the sources above is actually v1.03 build 20190924.
There was an earlier build of v1.03, which is build 20190911.
I have two A113V3 dash cams here, with those two different v1.03 builds, and the 20190911 behaves at it should - gets out of parking mode as described in VIOFO's reply above, while 20190924 doesn't, even though both have 100% identical settings, and I use them in the same GPS mount (not at the same time, of course
![Smile :-) :-)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
. Funnily enough, the camera loaded with 20190911, has a higher Serial Number. I wonder if the h/w build standard may also be different.
I'd like to continue investigation, but I need both BIN files for that, and I only have 20190924.
Can anyone help with the 20190911 file? Thanks.
