Tay-ST
Hi All,
Just an information sharing;
Device
70Mai Smart Dash Cam-7134
Model : Midrive D01
(70mai_d01_7134)
mac address: 38:83:9a:77:71:34
70mai_d01_7134 version is 1.08.ww
70mai phone app is version 1.11.0
Every time upon starting my car, the 70mai smart dash kept asking me to activate via phone.
" 70mai first boot up, requires to activate by mobile phone"
After activation succeeded/ completed, via phone's 70mai apps, recordings of footage resume normal.
However, it kept repeating above whenever the car is restart or the smart dash is powered on.
I brought the above unit home to diagnose with a USB power bank, symptom persisted.
I had tried several methods as below, but the problem persisted.
# hard reset the 70mai smart dash,
# So soft reset the cam by press 5 time on the cam button.
# Delete smart dash from app, re-setup.
# Downgrade 70mai phone apps from 1.11.0 to 1.7.3
All above resulted helpless.
Till, help desk replied that kind of flashing link is broken few days back.
After browsing this informative forum,
Finally, managed to resume above 70Mai D01 to operation mode.
Re flashing the firmware to 1.03, then again to 1.08EU (Unable to locate version 1.08ww) by SD card method.
Will monitor further and hopes it can last me further....
Firmware link
* The is a text file in the attachment for flashing instructions.
However, the device didn't prompt "Upgrade Succeeded" after completion (Unlike 1.03 version's)
Thus, I unplug the power 2~3 minutes after the Blue blinking LED turns off.
Methods
Hopes above could give everyone a course of direction to trouble solving.
Cheers,
Device
Model : Midrive D01
(70mai_d01_7134)
Firmware link
70mai Firmware Update (changing from Chinese to English)
Just cut first 32 bytes from factory sdcardv.bin file with a hex editor (eg. HxD). It should start with MCR2 instead of AITS. Flash that to eeprom. Hello everyone. I find myself the same problem, you could indicate the chip to be reprogrammed. Thank you You could tell me the function of the...
dashcamtalk.com
Methods
Hi, just update firmware in app and then in menu you should see option to turn off voice control. Wow, cool! I thought I'm on the latest firmware because I could not find any update button in the app. Which version is the latest for international version? I'm on 1.0.5.ww 2018-02-05 (at least...
dashcamtalk.com
Cheers,
