I'm cc @Thinkware Dash Cam just in case they might have the answer or suggestions:
Would anyone have any idea why day time it's stop with about 2rs parking mode recording?
I've been contacting with @BlackboxMyCar and they are very helpful. Below are the scenarios from online support.
Q800Pro and Cellink Neo battery.
Samsung PRO Endurance 128GB Micro SDXC Card with Adapter - 100MB/s U1 (MB-MJ128GA/AM)
Hardwired Neo to empty fuse slot (Switch) using 15A.
Output cable used: Power Output Cable w/ spliced BlackboxMyCar Hardwire Kit
App Setting: Parking Mode--Motion Detection; Battery Protection--Disabled; Record Timer=12hrs then later change to Disabled
Issue: Dashcam stop record about 2hrs after going to parking mode--motion detection
* The first few days, everything working good with parking mode. It was able to record from 7am to 6:30pm. When I'm home, I switch Neo to OFF since the car parked in a driveway.
* On the 3rd day when I'm at the parking lot, (I did not open car door or anything) open Neo app and Neo show "Not Use" 80% Temp 46C
* Start my car and review parking mode: No recording after 2hrs. At first I thought because of direct sun.
* Next day parked opposite of the sun. Same result: Neo app show "Not Use" 90% Temp 56C
* Next day, disable parking mode but then once engine shut off, Q800Pro also shut off. I don't see red led show on dashcam so I assumed it shut off
* Yesterday when I'm home, I did not switch Neo OFF and let it do the parking record to see if it stop in 2hrs. Guess what? It recorded. Parking mode record started 6:15pm until next morning before I start my car. Neo battery still remain at 74% temp 26C
I will update when I'm at my car today and see if it record or not..... Stay tune
Thank you.
Thank you.
