I had bought A129 Pro without any rear camera thinking that I could get IR later as there were (are) no "PRO DUO IR" set.
I thought IR would be better, becase:
- It could benefit from lack of IR-cut filter even if I always use "Color Mode" to turn off leds to prevent reflections related to rear lines on the rear window + any other reflection caused by the tint. So, even without the IR-Leds, it could show me more detail with the help of natural IR available around.
- It has wider FOV, so it could show more of the action.
- I did not (still do not) care about the pinkish cast caused by the lackness of IR-cut filter.
If I did wrong, that means I will be paying more to non-IR rear cam as I had not bought the pro duo set, if I am right, I will buy IR rear cam and use Color Mode. I need your help. I will be glad if you share your experience. What would you do if you were in my shoes?
