rcg530
- Jan 23, 2021
- California
- United States
- 70mai, BlackVue, Thinkware, Vantrue, Vueroid, VIOFO
While attending the 2024 SEMA show, I was able to speak with Redtiger / Wolfbox representatives about their current offerings. After returning from the show and then going through a long vetting process, I was sent a Redtiger F77 2-Channel dash camera to test/review.
This past weekend, I received the F77 dash camera and its hardwire kit. I've created my initial unboxing pictures.
- F77 2-Channel Dash Camera
- Front Camera
- Image Sensor: Sony STARVIS 2 IMX678
- Lens: F/1.8 Aperture [still researching FOV/AOV]
- Storage - Internal
- 128 GB eMMC - Videos are written to this storage
- Storage - External
- MicroSD Card - Used to backup video files from the eMMC storage and it can be used as the source for video playback
- It appears 128 GB may be the max storage supported [still investigating this]
- WiFi
- 2.4 GHz & 5 GHz [shown as 5.8 GHz in marketing info]
- Rear Camera
- Cable
- USB-C Front 90-degree connector / USB-C Rear 90-degree connector
- Length: 6.50 M / 21.32 FT
- Cable Thickness: 4.69 mm / 0.184 inches
- In The Box
- F77 User Manual
- F77 Quick Start Guide
- Four (4) Electrostatic Stickers
- Extra Front Camera Windshield Mount
- Replacement Front & Rear Adhesive Pads
- Five (5) Cable Clips
- Plastic Installation Tool
- Data Cable
- USB Type-A to USB Type-C
- Length: 1.00 m / 3.28 ft
- Power Adapter
- Type: Cigarette Lighter / Power Port [12V - 24V]
- Length: 3.45 m / 11.31 ft
- Output:
- Dash Camera: 5V 2.5A
- USB Type-A port: 5V 2.0A
- Redtiger Hardwire Kit - RTH30GS
- Low Voltage Cutoff Settings
- 12.4V / 24.4V
- 12.0V / 24.0V
- 11.6V / 23.6V
- 12V / 24V Wires
- Yellow = Battery Constant Power
- Red = Switched / Accessory Power
- Black = Ground
- Status / Display
- Shows whether "ACC"essory power is on or when its off it displays the current input voltage level
- In-The-Package
- User Guide
- Two (2) - Fuse Tap Kits
- Each fuse tap kit contains: four (4) most common fuse tap types
- Adhesive Pad
- Front Camera
