I have to respectfully disagree with the advice being offered in this post because it is incorrect and it will likely degrade the image playback quality of your dash cam videos rather than improve them.
I can understand how experimenting with the different available settings in VLC might sometimes give the illusion of improvement but close scrutiny of certain image details reveals how the software is really effecting the images. For example, the cropped image grabs I show below were taken from a full screen 1920 x 1080 video where the overall effect of deinterlacing could be hard to judge and even at times "appeared" to improve the image quality until one looks closely at certain areas and details that make the effect of the deinterlace filters quite obvious.
The reason this technique doesn't work is very simple, although the explanation can get a bit complicated. Assuming our dash cams are actually shooting
1080P Full HD video, we are working with a signal that is NOT
interlaced. If you attempt to "
deinterlace" video that is
not interlaced to begin with you will only generate unwanted artifacts and distortions during playback.
The
"P" in
1080P stands for
progressive.
Progressive scanning is a way of transmitting and displaying moving images in which
all the lines of e
ach frame are drawn in sequence. This is in contrast to
interlaced video used in traditional analog television systems and certain digital broadcasts such as
1080i where
only the odd lines, then the even lines of each frame are drawn alternately, so that
only half the number of actual image frames are used to produce video.
Interlaced video is a technique for doubling the
perceived frame rate of a video display. The
"i" in
1080i stands for
interlaced. Interlaced video is often (usually) found on commercial DVDs and this is where the De-interlace settings in software such as VLC can be invaluable when you watch movies on an LCD computer screen.
And so this is why if you attempt to "de-interlace" a video that is NOT "interlaced" you risk creating unwanted and unintended problems.
Here are some cropped screen captures I've made in VLC to demonstrate what I am talking about.
In this image "De-interlace" is set to
"OFF".
"ON" with the above recommended
"Bob" algorithm selected.
In simple terms Bob is considered a "doubler" and so it basically doubles the frame rate of the scanned fields.
The detrimental effects of doubling the fields of a non-interlaced video are obvious.
In this image the De-interlace algorithm filter is set to
"YADIF". It checks pixels of previous, current and next frames to re-create the missing interlaced field using an adaptive method.
The effect is more subtle but is definitely not an improvement.
(BTW, YADIF stands for "Yet Another DeInterlacing Filter".
Please note: I also made a screen shot using the above recommended "YADIF (x2) setting but it comes out looking completely normal as a single still frame so I haven't posted it. During actual playback of the same video images I'm showing here there is a visible "shimmering" of the alternating, artificially introduced scan lines, especially on the front grill of the Ford SUV in the screen capture. When these types of filters are used properly on an interlaced video, the quick alternating display produces a convincing illusion of full vertical resolution while playback is running but when used on a non-interlaced video source you'll get a shimmering effect like I describe, especially on specular highlights.
Finally, on another note, I fully agree with the suggestion to change the gamma values when viewing certain videos in VLC. This can dramatically open up dark shadow details that were otherwise obscured but do exist in the original. The important thing to know is that you are
lowering the Gamma Curve correction values, not
increasing them. "Powers larger than 1 make the shadows darker, while powers smaller than 1 make dark regions lighter." VLC makes this confusing because the slider control actually lowers the values the more you move it to the right which is backwards and make the user believe he is raising the values.
See this link for more info.
Edit: The above screen grabs are from a Mobius camera fitted with a "B" lens on the "wide" setting.
