Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Thank you @DiggCams for providing Nano Q/mini 0903 dash camera for review.
Product site: http://www.diggcams.com/mini-0903nano-q-novatek-nt96655-sony-imx322-dash-cam-p-1399.html
Quick links to review sections:
Daytime Screenshots
Daytime Videos
Night Screenshots
Night Videos
Conclusion: will update after tests.
PROS:
CONS:
Description from product site:
The Mini 0903 a.k.a. NanoQ is the latest and smallest model to the popular ultra-compact Mini range of car dash cameras offering an even smaller footprint than the ever popular Mini 0806 model and replacing the older and now discontinued Mini 0803 model.
This is the camera to have if you want to hide it away behind your rear view mirror. Being smaller than the Mini 0801, Mini 0805 and Mini 0806, the NanoQ can be tucked right behind the mirror allowing the most discreet install of any dash camera with a built in screen. In fact, this camera is much smaller than most cameras without a screen!
The Mini0903 / NanoQ can record up to 2MP HD 1080p at real-time 30 frames per second. The Sony Exmor IMX322 CMOS Sensor excels at night giving crisp video no matter what time of day you are driving. Video can be viewed on the camera's 1.5" LCD screen which is also used for adjusting menu settings and aligning the camera easily. The Mini0903 / NanoQ can be mounted as a left or right-handed camera, giving a greater level of flexibility when choosing an the best installation location for your car.
The Mini0903 / NanoQ uses a high dynamic range (HDR) to improve it's ability to record in low light conditions and also offers the ability to attach a circular polarising lens (CPL) to the lens using a simple magnetic ring (no need to clip or screw on). This can help to reduce glare which may otherwise impact video quality and is highly recommended for the UK. As such, this is included in all NanoQs we sell.
The included GPS module enables the Mini0903 / NanoQ to pinpoint your location and calculate your speed which can offer additional evidence should there be an incident or help your case should you need to make an insurance claim. This information can be viewed via the software provided on the camera.
This also features super capacitor so should behave better in extreme weather conditions.
Product box is very small, only 5.25"x3.25"x3.25" and camera is well packed inside.
Unboxing Video:
Package contents:
1. Nano Q/ mini 0903 Dashcam.
2. Sticky mount with GPS.
3. micro USB car charger with additional USB port. Nice!
4. USB to micro USB power cable.
5. Two VHB tapes for the mount.
6. Product manual.
7. Lens cleaning microfiber cloth.
8. Extra mount to use with other GoPro like brackets.
![DSC03994-NanoQ.jpg DSC03994-NanoQ.jpg](https://dashcamtalk.com/forum/data/attachments/21/21099-5116b75a9f2f1aeebc48466264c423f7.jpg?hash=URa3Wp8vGu)
Nano Q/mini 0903 Side-by-side with mini 0826.
mini 0826 doesn't look mini anymore when Nano Q is next to it.
Nano Q is very small, only 2.5"x1.5" and will be more discrete.
Front: lens and vents. Lens has rings for optional CPL.
![DSC04044-NanoQ-0826.jpg DSC04044-NanoQ-0826.jpg](https://dashcamtalk.com/forum/data/attachments/21/21100-6670e3e5a428bc36da70a76068996d0e.jpg?hash=ZnDj5aQovD)
Bottom: microSD slot and mini HDMI.
![DSC04045-NanoQ-0826.jpg DSC04045-NanoQ-0826.jpg](https://dashcamtalk.com/forum/data/attachments/21/21101-b7a3388490e565df0fd254b2132ca0f6.jpg?hash=t6M4hJDlZd)
Nothing on the right side.
![DSC04046-NanoQ-0826.jpg DSC04046-NanoQ-0826.jpg](https://dashcamtalk.com/forum/data/attachments/21/21102-9e719f6cae56d01a611037a8d471ec56.jpg?hash=nnGfbK5W0B)
Top: micro USB port, mount connector, AV out port![DSC04047-NanoQ-0826.jpg DSC04047-NanoQ-0826.jpg](https://dashcamtalk.com/forum/data/attachments/21/21103-ea5d4b923da5c7dd3b5b4905e2a74264.jpg?hash=6l1Lkj2lx9)
Nothing on the left side.![DSC04048-NanoQ-0826.jpg DSC04048-NanoQ-0826.jpg](https://dashcamtalk.com/forum/data/attachments/21/21104-0812acf8ef6373057c6181fa8b1d9761.jpg?hash=CBKs-O9jcw)
Back: 1.5" LCD screen and buttons on each side.
M/mode button cycles through video resolutions directly. Nice feature!
![DSC04049-NanoQ-0826.jpg DSC04049-NanoQ-0826.jpg](https://dashcamtalk.com/forum/data/attachments/21/21105-9cf60217b2a679623277c3c18b1a1c65.jpg?hash=nPYCF7KmeW)
Nano Q Folders and Files:
Root has the following folders:
DCIM: It has MOVIE subfolder that has all the video files.
GPS: It has GPS data in log files.
![Nano Q folders and files.PNG Nano Q folders and files.PNG](https://dashcamtalk.com/forum/data/attachments/21/21106-336c7801407913b2c87fb7b9d33198c2.jpg?hash=M2x4AUB5E7)
File size and VBR of a 3 minute video file: Overall bit rate is 13.1 mbps with 11.9mbps video and 512kbps audio bit rate. File size is around 280mb for 3 minutes.
Mediainfo properties:
File size : 280 MiB
Duration : 3mn 0s
Overall bit rate : 13.1 Mbps
Video Bit rate : 11.9 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Audio Bit rate : 512 Kbps
Channel(s) : 1 channel
Sampling rate : 32.0 KHz
Daytime Screenshots
Daytime Videos
Night Screenshots
Night Videos
PROS:
CONS:
Unboxing Video:
Package contents:
6. Product manual.
File size : 280 MiB
Duration : 3mn 0s
