Hack_man
I agree and why bother having a timer setting for PlatePix if it defaults to the HDR timer's setting.If PlatePix only works when HDR is enabled it should be mentioned in the app, or the on-screen display, or the manual.
Don't need a monitor, but a 4K TV will do to see the differences.It does seem that the default exposure is a bit brighter with Viofo than with Vantrue. Plus, the grey back dash and trunk lid also take up nearly half of the frame for the rear camera, so that will tend to push the auto exposure level up just a bit, helping to wash out the sky.
It's curious, after playing with a few cameras you get to see the patterns that reveal the specific design philosophies and choices that define the brands. I suspect my comparisons might reveal different kinds of things related to overall detail and sharpness if I had a monitor that could display the full resolution of each video file.
Ha - didn't think of connecting my computer to the television. I have a 65" 4K. Don't think the rest of the family would appreciate several hours of my videos while I fool around with time alignment and screen caps...Don't need a monitor, but a 4K TV will do to see the differences.
I made a few images last night in an effort to compare various modes of the N4S camera and to compare it to the A139Pro. This first set of images is a screen cap from while I was moving at about 35 mph on a road this is fairly dark. There are a few street lights but not many.
From the A139Pro, HDR on, polarizer in place:
Vantrue N4S, HDR on, PlatePix On, Polarizer in place:
Vantrue N4S, HDR off, PlatePix On, Polarizer in place:
Vantrue N4S, HDR off, PlatePix off, Polarizer in place:
Again, the Viofo produces the brightest image as well as the image with the greatest amount of detail in the two illuminated signs that are on the left hand side of the road attached to the buildings. The image with the next greatest level of detail looks like the N4S with HDR off and PlatePix On, You can also see the varying levels to which the small house on the right side of the road is visible or not with various settings.
This is kind of my starting assumption because there are two separate controls in the menu/app. The video evidence seems to bear this out as well. There are subtle, yet clear differences in the set of images with various settings.
Why does my N4S PlatePix timer always change to what the HDR timer is set to if these are separate features? I set a different time for PlatePix than HDR and it changes to whatever I set for HDR . This happens after I confirm my PlatePix timer settings, and then exit and re-enter the PlatePix timer menu. The PlatePix ON/OFF times gets reset to HDR timer ON/OFF values.
I asked Vantrue this question and the answer was "PlatePix only works when HDR is enabled, so its timer follows the HDR timer setting"
I am a bit confused.
The A139 Pro only has HDR on the front camera.A139Pro Rear camera, HDR on (though I'm not sure if this impacts the rear camera or not):
My conclusion is that PlatePix is HDR, it just gives different HDR exposure settings with PlatePix On/Off, and sometimes adds some extra digital sharpening and tone mapping, depending on exposure. If HDR is turned off then PlatePix is also Off.I recall @Nigel did some testing of the E1 Pro with HDR on/off and PlatePix on/off and came to a similar conclusion.
This is exactly what Vantrue told me.If HDR is turned off then PlatePix is also Off.
Your statement is consistent with what Vantrue says about PlatePix:My conclusion is that PlatePix is HDR, it just gives different HDR exposure settings with PlatePix On/Off, and sometimes adds some extra digital sharpening and tone mapping, depending on exposure.
That's a good idea to cycle thru all of the settings for HDR and PlatePix without moving. It seems like PlatePix is an advanced version of HDR and should be rolled into one menu.All of this makes a lot of sense to me: PlatePix and HRD utilize similar kinds of algorithms, but with varying parameters concerning the relative strength of contrast, noise removal, and sharpening settings. I'll have to see if I find a better spot at night where I can sit for a few minutes without moving and cycle through all of the settings and do some additional image and video captures.
With the Viofo A139 Pro and A229 Pro, turning HDR off during daylight is definitely better for reading plates unless you have unusually bright lighting conditions, Dr McCoy is correct.Reference Post #106 by @Chuck McCoy suggesting HDR degrades image quality during daytime but this was not considering PlatePix
