That was an interesting install - a few of you know that I have my car pretty well wired for multiple cameras at a time, but the challenge I faced this time is that all of my existing wiring assumes a top-center windshield mount position. This is my first install that needs wires run to the lower center windshield. Here is what I ended up doing:
Here is the thermal cam mounting position - that emblem is just about perfect for small, exterior camera mounting
🙂. The camera is mounted to the N4S rear camera bracket with VHB as shown a few posts above. I also added a strip of VHB to the bottom of the metal bracket so I could stick it to the horizontal surface just above the "Volvo" lettering inside the emblem as you see below. But, rather than sticking the VHB-clad metal mounting bracket directly to the horizontal part of the emblem (which might make it nearly impossible to remove in the future), I applied a square of windshield static cling to the horizontal surface of the emblem. The static cling is thus placed between the VHB/bracket combo and the horizontal surface inside the emblem. This part of the plastic has been polished smooth and cleaned well with alcohol to insure the static cling sheet actually clings! If the camera comes loose, I've anchored the cable just behind the grille so it won't fall completely off the car and get dragged on the road.
It was just about a perfect fit when I did my "dry fit" placement test. But adding the layer of VHB between the bracket and the horizontal part of the emblem made things tighter than I expected - this resulted in tipping the thermal camera down a bit more than I expected, but looking at the footage I captured this evening, it looks just about right with a bit more road than sky. This mounting position places the camera exactly 24" above the road surface.
The screw terminal that joins the thermal camera wire to the longer thermal-to-USB cable also got some VHB so I could stick it to the underside of some trim work under the hood. Then I ran the cable under some other trim work and along the side of the car toward the door.
Volvos tend to be buttoned up pretty tightly and access to rubber grommets in the firewall is easier to find on the inside of the car (which is still not easy) compared to in the engine compartment, which is pretty full and covered with all kinds of sound deadening material. It makes for a nice quiet car, but it's a bear trying to poke wires through and then find them on the other side. Sigh... I did find a place to run the wire along the inside of the exterior body panel that was accessible from under the hood. I was able to pull the wire through an opening right next to the top door hinge. I ran the wire below the hinge and pulled it back up again to enter the car.
Next, I ran the cable under the rubber trim for my door. I pulled the door seal off and tucked the wire between the seal and the metal of the car body and put the seal back in place. I thought this might be better than running the wire across the top of the door seal. I'm not super happy with this install, but the flat cable sure helps minimize the disruption to the rubber trim for my passenger side door! When Vantrue released their earlier dashcams with weather-proof, external rear cams, I suggested that they make this a flat rather than a round cable for exactly this install scenario. Having a flat cable that is only 2mm thick helps immensely with wiring options!
I purposefully angled the wire downward as it passed under the rubber seal (shown below) so that if water finds its way into the opening, gravity will pull the water toward the outside of the car instead of toward the inside. That's the theory, at least - dunno if it will actually work to keep water out. Then I coiled the excess wire behind a trim panel (center of image below), put the panel back, and ran the rest of the wire up onto the dashboard for the P2 main display unit.
Here is the wiring for the main camera, mounted at the top of the passenger side, close to the windshield center. That new mount is AWESOME for mounting the camera.
@Jeff_Vantrue - congrats are due to the design team for this new mount - I really like it!
And here is the main display unit resting on my dash. I added a thin layer of adhesive foam weather stripping to the bottom of the unit to soften that crisp metal edge and protect my leather dashboard. I also switched mounts to try the aluminum one AND managed to install the screen with the proper orientation this time
😉. I like that indicator ring on the red pump to show you that you have sufficient vacuum to hold things securely to the windshield! As
@jsmith commented on, I found the keyed-USB cable that connects the main camera to the display unit to be about 3ft/1m longer than necessary for my sedan. I didn't find a convenient spot to tuck away the excess wire, so for now, it's just laying on my dash...
EDIT: After having this camera installed for the past 2 months, my mounting methods have held up well! The thermal camera is still stuck fast in my grille emblem, the main display unit has stayed put (with occasional pumping of the arm to renew the vacuum mount), and the cable that I ran under the weather stripping hasn't resulted in any water infiltration! Awesome!
