- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
if you have some more screenshots of the filename order being out is helpful
I'll see if I have some on my laptop, but I can tell you the whole filename was exactly the same between the two clips (besides one being A and one being B, of course), but the rear file was named 2 seconds laterif you have some more screenshots of the filename order being out is helpful
But surely they're supposed to have the exact same filename?if the fie name order is correct but it's just the timing difference between the front and rear files that may be something that needs to be adjusted in the player, will have to talk to @traveler about that, will check with the engineer anyway
I get ya. DCV could probably do with some logic to bundle anything a few seconds either side together and then synced up so the view can be toggled front or backBut surely they're supposed to have the exact same filename?
the file name is based on time, if the camera is doing things and it takes time to write out the fie from memory because it's recycling files, updating GPS sync or whatever then the two files are not always going to be at the exact same time, that is what I expect is happening but I'll ask the engineer to look at it, I suspect it's something that the player needs to do differently though
This just happened again. Unfortunately I wasn't driving it, my wife was, so she never held down the power button like you suggested. It's getting a bit concerning as it seems to be happening at least once a week nowThere is definitely an issue with the camera FW. I loaded up 1.18 pretty much immediately after installing it a week ago, so I can't say whether it is 1.18 or a bug in an earlier version.
This is the second time this has happened in a week:
1) The camera doesn't power on after 5 seconds from ignition on.
2) It then does power on after a bit and stays on the boot logo for ages.
3) It beeps away and then says "please format the TF card".
4) It beeps again and gives me the option to delete all data.
5) I press OK and it boots up again without having fixed the issue.
6) The only way to force it out of this loop is to pull the power and put it back in. When it restarts all works fine again.
Here is a video: https://www.dropbox.com/s/3riqczoawfbs9ou/20180225_164327.mp4?dl=0
I'm thinking loading the last stable release is best. Do you have a link?You said you loaded the beta firmware right away. Maybe go back to the release firmware to test and confirm things return back to normal for now. What type of vehicle do you have? Diesel engine at all?
It's a 2017 Hyundai Tucson, petrol
This one ^Toshiba Exceria M302 128GB. I cleared it with Niko before I bought it from amazonforgot to ask, what memory card are you using?
This one ^
My friend has the same cam and same memory card. Just asked him and he said he's not on 1.18 and he's not had any issues at all. Must be this beta thenwe are working on improved card support at the moment, I'm not sure it's a card issue anyway but helps to have the info for reference
