arcticfire
- Jun 28, 2015
- United Kingdom
I can't see a public thread on this so thought I'd make one up as I've got a few requests if possible?
These are my more pressing ones :
1. Some form of menu/button protection from unauthorised access which can be turned on in the menu be it either a button sequence or more preferably a pin. Would be very good for commercial use reasons. The cable tidy cover already gives a little bit of protection for the power cable.
2. An audible alarm which will continually beep when a card read or any error is detected until switched off in the menu. Again it should be a feature that can be disabled in menu in case s user doesn't want this feature. Good for commercial purposes to ensure drivers report an error straight away, unless they don't mind the beeping all day. Also would be good because I have experienced an occurrence where the red light is flashing and the screen shows recording but nothing was being written to the card. This happened when the card got corrupted whilst playing with the hardwire kit.
3. The option to stamp the GPS speed in the video. Makes life easier to show speed in exported footage, unless there's another way to stamp the speed from GPS data on software?
A couple of desires...
4. Ability to select different bitrate or quality levels so that if storage capacity is more important than maximum image quality then at least you have the choice.
5. Selectable min. frame rate. Not sure if this is very easy or even possible through firmware?
Not mentioning the exposure issues as I know they are already being dealt with.
Cheers!
Cheers!
