SOOCOO S300 CMOS Sony IMX377 with Hisilicon Hi3559V100 (4k/30FPS)
TCalin
Romania
For what i have seen unitll now, the battery goes down to 0 and to protect it i have removed it from the camera when i'm not using it. Anyway, i have sent a message on their official site with the problem and they said that they will look into it, but that was some time ago and the fw updates released 'till now haven't done any good. Also, they aren't responding to any message from some time ago.
dct-mrTee
How great the battery drain? All of my cams must use some battery potential maintaining settings. .
My experience so far, battery drain situation seemed to improve somewhat in the latest fw (v.20180218). It used to get to very low level in 2-3 days and power itself off when I turned on. Now I still get some power left to record (about 10 min) after 7-8 days. I bought extra batteries, so hopefully they'll be handy for longer trips. Like I mentioned before, I cannot get IS and LDC on at the same time (any recording modes) in current fw. But I have not experienced the freeze frame so far (in 4k30p). Although, I have not tested them in all recording modes. We'll see.
TCalin
Romania
Can you please tell me what sd card do you use? I think that maybe the card is to blame for the freezes. I have a Kingston 64Gb SDXC class 10 uhsi 1 and i know that it's not suitable for 4k recordings but it should be ok for 1080p at 30 or 60 fps, i guess.
D
Deleted member 24437
Guest
SDXC should indicate an U3 card, which would be adequate for 4k recording! Doesn't it have the U3 symbol?
TCalin
Romania
No, it's just U1...but shouldn't be ok for 1080p at 30 or 60 fps?
D
Guest
I have SanDisk(WD) extreme pros of 64 gigs! Satisfied with them in my Yi 4k+ at 4k/60, also a no-name Amplin from Amazon works well!
managatsuo
Ireland
Hi I want to buy my first action camera, but can decide between s300 or Firefly 8s 90° , I like the narrower FOW on Firefly, but I can see some option to change FOW on S300, can you tell me please that the option helps to remove distortion and fish eye effect, also anyone has Eken H5s + ,as I considered that as one of the option but also has 170degrees FOw? thank you for any advice. Peter
TCalin
Romania
Yeah...another "great" update. Still can't use LDC and EIS together.
TCalin
Romania
So..i was comparing my old SJ4000 with the new S300 and i saw something that doesn't look right. When filming on 4K it suppose to be filming with 30 fps..but the movie properties says that the movie is made with only 5fps. Also..the bitrate on SJ seems to be bigger than the S300's. Can you check your movies to see if it 's the same problem?
TCalin
Romania
Well after looking into it..it seems that the card dind't have the necessary write speed.
888Ken888
Hong Kong
Hi, I want to ask when the cam finished the charging will change the colour of the light? My S300 keep show red light even after charging overnight?
TCalin
Romania
Yes , when the charging is finished, a green or blue light must be on.
888Ken888
Hong Kong
I updated the newest firmware but still can't change colour after all night charging and the seller claims that it was S300 issue. What can I do >__<
TCalin
Romania
Well, if the seller sais it is a S300 issue, he must solve your problem, replacing the battery if is dead...or the camera if is faulty. Taltk to the seller and ask him to change the camera on warranty, or to offer you a solution to your problem.
D
Guest
Many brands of inexpensive action cams are not made by the name on the camera- one reason I buy Yi tech.
c4rc4m
Viofo WR1, A119 Pro. VicoVation Opia 2, Mobius 1
Not necessarily. the U rating is for stills. What matters for Video is the V Rating. It needs to be V60 or V90 for 4k. You can sometimes get away with V30, but the camera would have to have quite a low bitrate. The number relates to MB/Sec so should be fairly ease to match to the camera.
