HunkyWunky
- Mar 8, 2015
Rayman,
Just offer us the supercap version
Rayman,
Does this mean that if we buy an 0806/Batch#3 that at some point in the future we can replace the Li battery with a supercap?
Hopefully you will resolve problem with Samsung memory cards too. I can see here that I am not alone with that problem. For now my cam is unusable - it records just random time of journey and hangs up.firmware is nothing related with those, we continue works on debug and improve.
3rd batch different:
PCBA:
change the blue power LED to be hardwire control, so it will be ON when power connected, no matter if the camera is ON
re-shape the PCB corners so it will fit into the housing better, no stick with housing.
HOUSING:
rework the rotating ring and housing, to avoid the GPS cable cutting
remove the unwanted plastic materials to fit in a supper cap battery
I normally leave the CPL on to cover the lens but the CPL keeps rotating to the wrong position if being carried.
Thank you for the tip. How does blue tak perform in hot weather?I had a similar issue, which I solved by using a tiny dab of blue tak under the edge of the CPL.
The magnetic attachment is a neat idea, but not nearly strong enough to make me happy.
grnbrg
I wouldn't use it to hold the camera to the windshield. But it should keep the filter on and steady with no issues.Thank you for the tip. How does blue tak perform in hot weather?
Gotcha'. My filter falls off fairly easily making it impossible to use my sunshade for the windshield when parked during the summer months.I wouldn't use it to hold the camera to the windshield. But it should keep the filter on and steady with no issues.
And less is more when it comes to using it.
grnbrg.
