Is this considered the 3rd batch of cameras that I read before was supposed to come out in March?
JooVuu is not stocking the camera's at the moment due to quality issues. Our return rate is over 12%.
Kind regards,
JooVuu
Yes, it is the 3rd batch.
Partly identification, but the dye is also used in a 'raddle harness' to see which ewes have had attention from a 'tup'. Same goes for goats.off topic...why are sheeps with red dye on back?
Is there a difference between the second batch and the third? What is the different if there are any?BlackBoxed Kelvin, current shipping is 2nd batch.
and the 2nd batch has out of stock for now.
the 3rd batch PCB will come back soon, so the products will be distributed from the month end to Apr begining. Most have been pre-ordered; only few quantity left now.
The 3rd batch PCB will come back soon, so the products will be distributed from the month end to Apr begining. Most have been pre-ordered; only few quantity left now.
Rayman, I received a 2nd batch camera that was badly out of focus. Has the production issue with incorrect focus been corrected for the 3rd batch? I am looking to buy a 2nd cam for rear view but don't want to have to open it up to fix it.
Awesome news about the capacitor - it's great to see you guys keep improving this one Raymanrework the rotating ring and housing, to avoid the GPS cable cutting
remove the unwanted plastic materials to fit in a supper cap battery
firmware is nothing related with those, we continue works on debug and improve.
Thanks Rayman,Nigel, I can't help to use "save as ..." when i saw your images here.
you genius!
should we use mini 0806 as a dash camera or a digital camera?
It is good that you are continually making improvements. It is also one more example of the risks of being an early adopter.3rd batch different:
PCBA:
change the blue power LED to be hardwire control, so it will be ON when power connected, no matter if the camera is ON
re-shape the PCB corners so it will fit into the housing better, no stick with housing.
HOUSING:
thx...now I learned something....Partly identification, but the dye is also used in a 'raddle harness' to see which ewes have had attention from a 'tup'. Same goes for goats.
PCBA:
HOUSING:
PCBA:
HOUSING:
