Coming from the Dexors X7, and previously a Papago GoSafe520, I'm surprised a suction mount with at least a flat surface isn't available. The flat surface could mount virtually any other mount with adhesive strips.
The issue is, the company I work for doesn't allow permanent fixtures on their equipment. Adhesive is basically permanent in regards to leaving the plastic mout attached. How do you keep removing adhesive and have it retain its adhesive properties?
With my Dexors, which has an excellent twist-lock suction mount, has a low profile design. I can mount or remove in just a couple seconds and is perfectly stable.
I believe you can still get a good stealthy design with a suction mount.
Just need to find a way to work them together.
I'm not trying to bash the Street Guardian, but I feel for the price, that a suction mount should at least be an option.
I sometimes drive different tractors, even so...I remove the dashcam everyday.....especially being a $200 unit.
Here's my Dexors mount next to the Street Guardian, then with the mounting point of the v3 on the flat surface of the Dexors mount
Replace the Dexors mounting tap with a quick release for the v3 dashcam and there would be room for the wires.
