Margate5
Having the full A139 dash cam system installed. Will post pics later.
Well done But the coax at the rear can might be bent into too sharp a radius. No reports on cams with it yet, but it's essentially the same as RG-174 coax for radio, and that should have about a 4" (100mm) minimum bend radius. What happens with it is that over time the center conductor can press into it's insulation and 'migrate' toward the outer shield, first changing impedance then possibly shorting. USB type cables are more forgiving of tighter bends but are larger diameter.
I'm not sure if this was ever added to the owner's manual but it was discussed here with Viofo agreeing that it shouldn't be bent tightly.
There was a 90 degree plug on some cables we testers got.
On the main unit i think strait plugs are a must, not least with the no tamper bracket, but in the camera unit end i think a angled plug make sense.
At least they are standard plugs so you can replace them if it is a major problem in your install, but otherwise i think it is as in so many places " deal with it or do something else"
Doing my #2 install with the replacement camera and mirror, this time around i did modify the trim around the mirror stalk to accommodate the wire better
I think Viofo needs to produce a 90 degree plug for all the reasons @SawMaster pointed out. Having to bend the plug and make it work, is asking for trouble. There's no graceful way to make that plug not bend. Only thing you can do is offer more slack and not make a sharp bend.
Is the 90 degree plug something that would be easy to swap out if it could be ordered either if Viofi starts to offer them or you can buy one online from aliexpress as was mentioned? Or if the straight one I have broke is it difficult to have replaced?
I would like a 90 degree plug if possible as I don’t want any issues down the road and now while it is new is the best time to get it addressed.
No. I doubt your installer would do this for free. It requires removing the Hatch Trim, pulling out the cord from the rubber grommet, and pulling out the cabling from the rear camera all the way to the front camera. Then re-running the cable again with the new 90 degree (L) shaped cable.
Be careful about the connectors you choose. The ones i've mentioned/showed in another thread are from Aliexpress (because of the price and uncertainty whether the original are actually MMCX) and at least the straight ones are not as good as the genuine ones - the connectors from Ali have a different profile and wiggle a bit. It is not that bad but still, it's coax... and i would rather have more rigid connection since i used much thinner cable (+ i need to rule out one behaviour). I bought some 90° as well but haven't received yet, despite i ordered them about the same time as the straight ones and it's over a month already (no tracking unfortunately).I found a aliexpress listing for 10 of the plugs in angled, they cost just shy of 8 USD, but for some reason the strait ones i was not able to fin at least not in a 10 PCS package / lot to compare price.
Could be also the fact that MMCX are sometimes used for Audiophile applications which need some "special sauce" (not sure about impedance)I also found some really expensive ones, like 1 for 10 dollars, but they also looked a lot more "spiffy" than the simple ones.
K | Finally got this installed | A139 | 9 | |
A139 installation in 2018 BMW 3-series touring F31 | A139 | 6 | ||
G | New A139 hardwire install - erratic behaviour in parking mode | A139 | 31 | |
R | Finally installing the A139 "properly" | A139 | 6 | |
R | A139 installed. Looking for a memory good card | A139 | 4 |
