ChampaRando
Hi!
I own a Thinkware U1000 but was interested if anyone has a wi-fi API for it (I just need it to automatically pull event videos only, not all regular ones). I currently do this for this unbranded dashcam I have, and it works fine since it uses a Novatek API.
I also own a Viofo A139 3CH and doing that for it also works fine (battery is still not drained, I drive daily so not a problem).
I found the APIs for other cameras by sniffing packets of the android app & for Viofo, the API is available on the Novatek (the processor) wifi api pdf manual, but the thinkware app is not able to find the camera as soon as I start sniffing (since my sniffing app creates a local VPN and thinkware cannot work with that I suppose). It would be more annoying to try and use Wireshark for this so if anyone has an API that would be good?
I connected my U1000 to my wifi router as a "hotspot". So basically whenever I pull into my driveway, it says "wifi connected" and when I turn off the car, the wifi light is turned off, but somehow, I am still able to PING the camera and it shows up as a network device in my router. So I suppose camera is still working with its Wifi even in park mode! Correct? So I just need an API/commands/directory on how I can retrieve event files.
