R
Richard Ayrton
Guest
Better form factor than I was expecting. Thought it might have been covered on LEDs like some the real cheap cameras.
Welcome to the world of the cheapest generic dashcams. Oh, and welcome to DCT!Only 24fps from what I can make out.
It does as a 1st cam but the night performance varies wildly.
(...) for info this one suggests it has IR (...). It is a normal white led.
Thanks for the tip I'll try it at 720that makes more sense then, spec said 1080p30 which 96620 can't do but if it's 1080p24 it's interpolated, the chipset only supports native 720p and upscales to do its version of 1080p, with these you often find it will give better results when set to 720p
It's not only wide angle lens cameras. If I'm not mistaken, all dashcameras give that misleading perception.Thanks for the tip I'll try it at 720
As a side note on playback it makes it look as if I am driving a fair bit faster than I was, am I right in thinking this phenomenon is due to the wide angle lens? Is this common with dashcams with wide angle lenses?
