Unable to connect to WiFi
xRYD3Rx
Hi guys,
I'm unable to connect to the wifi I've done almost everything but can't figure out how to enable the wifi.
The wifi led flashes for a few seconds and then turns off.
I reset the wifi login by pressing and holding it directly on the dashcam.
I also tried by reformating via computer and going into the setting and enabling over the cloud + wifi.
However, I'm using a Samsung pro endurance 128gb micro sd card can this be the issue? *No issues with recording/parking mode with his micro sd*
Any tips or advice?
**ISSUE RESOLVED**
Wifi was turned off on the camera itself I pressed the Wifi button and it turned back on.
Rookie over here.
Well, that was an easy fix. Remember that it turns itself off after a while so you will likely need to switch it on 'next time'.
