nutsey
V60S Action Camera Review
![00-title.jpg 00-title.jpg](https://dashcamtalk.com/forum/data/attachments/29/29704-f457bfd17691cf0a7fb39f4a2949e3fb.jpg?hash=9Fe_0XaRzw)
Technical Specifications
Package and Accessories
The dimensions of the package are 265 mm * 162 mm * 62 mm (~2.7 L of volume), the weight is 563 g. The outer package cover contains detailed information about camera features and accessories.
![01-box-34.jpg 01-box-34.jpg](https://dashcamtalk.com/forum/data/attachments/29/29705-a3e6b3e7c264440b094f363e50ad850e.jpg?hash=o-az58JkRA)
There are 3 stickers on the box. One of them has information about the front panel color and the wall charger type.
![02-box-stickers.jpg 02-box-stickers.jpg](https://dashcamtalk.com/forum/data/attachments/29/29706-86f7428339be0a6e491da4ea86b2ea7c.jpg?hash=hvdCgzm-Cm)
The box is made of high-quality cardboard. It has a transparent plastic window which allows to see the camera inside the waterproof case and the remote control. The inner package part is a blister pack which holds the contents in place and protects it from any damage during transportation.
![03-box-inside.jpg 03-box-inside.jpg](https://dashcamtalk.com/forum/data/attachments/29/29707-1aad3e016b9a00cee9c31728dde56988.jpg?hash=Gq0-AWuaAM)
The camera bundle has a good and practical selection of standard mounting elements and accessories. It contains a remote control and a wrist band for it. It also includes a 2A europlug wall charger and a plastic frame with two 1/4" tripod screws. So the camera can be mounted upside down. V60S camera comes with a pretty detailed user's manual in English and Chinese and a leaflet which covers the remote control basic features and functions.
![04-bundle.jpg 04-bundle.jpg](https://dashcamtalk.com/forum/data/attachments/29/29708-109bcf5567737f615492d34c8d01f85b.jpg?hash=EJvPVWdzf2)
Camera Design
The camera body is made of black plastic, the front panel is also black and has soft-touch coating. V60S camera is also available with silver front panel. The protective lens rim outer diameter is 20.6 mm, the lens protrudes forward making it necessary to keep in mind protection against scratches and dents. The camera design is very common for a modern action camera, its front panel has following markings on it: ‘4K’, ‘ULTRA HD’, ‘2.4G’ and ‘WiFi’. Camera feels solid and the materials applied do not raise any questions.
![05-front-34.jpg 05-front-34.jpg](https://dashcamtalk.com/forum/data/attachments/29/29709-6723698978d4ed14c3ac57c932018cd5.jpg?hash=ZyNpiXjU7R)
Screen
V60S action camera uses the most popular among Allwinner V3-based products Sitronix ST7789v LCD driver. It works with 2-inch LCD display with mediocre viewing angles, colors become inverted only when you turn the camera to the right. Brightness is enough for shooting under different lighting conditions. The screen is not touch sensitive and is covered with glossy transparent protective film.
![06-lcd.jpg 06-lcd.jpg](https://dashcamtalk.com/forum/data/attachments/29/29710-923fe1074fabb82a7489604a2cc78a86.jpg?hash=kj_hB0-ruC)
Controls
The front panel has the power / mode button, it is also used for navigation through the menus. The shutter / ok button is located on the top. The left side has two buttons on it: up (short press - wifi, long press - digital zoom in) and down (short press - mute, long press - digital zoom out).
![07-controls.jpg 07-controls.jpg](https://dashcamtalk.com/forum/data/attachments/29/29711-004b9307a1d393115d98f3f89e854767.jpg?hash=AEuTB6HTkx)
Indicators
There are two LED indicators located on the back side of the camera. The red one lights up when the battery is charging, the blue one is permanently on when the camera is powered up. Another red LED is on the top, it starts blinking after switching on the WiFi connection.
Connectors
All connectors are located on the left side. Of these, there are microUSB and microHDMI sockets and a microSD card slot.
![08-connectors.jpg 08-connectors.jpg](https://dashcamtalk.com/forum/data/attachments/29/29712-318854b83b5cc84c17dc975b6c13cd2b.jpg?hash=MYhUuDtcyE)
- SoC: Allwinner V3
- Sensor: 8Mp 1/3.2” Sony IMX179s (1.4 μm pixel)
- Lens: Wide-angle 170-degree FOV (diagonal)
- Display: 2-inch LCD TFT screen, 320x240
- Video resolutions and format: 4K@30 fps, 2.7K@30 fps, 1080P@60/30 fps, 720P@120/60/30 fps. MP4 file format.
- Photo resolutions: 2M/5M/8M/12M/16M
- Connectors: microHDMI, microUSB
- Wireless features: Wi-Fi 802.11b/g/n, RF remote control
- Additional features: UVC webcam, 4x digital zoom
- Storage: microSD up to 64GB
- Battery: removable, 3.7v Li-ion 900mAh
- Dimensions: 59.1 mm * 41.0 mm * 25.0 mm (31.3 mm with lens)
- Weight: 60 g (44 g without battery)
Camera Design
Screen
Controls
Indicators
Connectors
