Trying to get some clarification on the new "HDR Timer" feature.
The updated user manual only states: "HDR Timer: The default is off, you can choose to turn on it in fixed time."
In understand the general idea of the HDR timer. It will enable HDR video recording at a specified time and turn off HDR recording at a specified time.
If I want to use the "HDR Timer" which video resolution setting must I select of the HDR capable video resolutions?
If I want the E1 to record 2560x1440P 30FPS video, do I select resolution "2560x1440P(HDR)30FPS", do I select "2560x1440P 30FPS" or does it matter as long as I select a video resolution that supports the HDR feature. I've observed the "HDR" screen popup just after powering up the E1 and the HDR feature should be turned on based on the timer and I've observed the "HDR with a slash through it" popup if the HDR feature should be turned off at that time.
The message when you enter the configuration screen for the "HDR Timer" of "HDR timer is only valid at the resolution with HDR function" implies that you must have a video resolution setting selected that supports the HDR function, but again does that mean you must select the resolution setting with "(HDR)" if the video resolution name?
I have one of my E1 units configured for resolution "2560x1440P(HDR)30FPS" and I have the HDR Timer feature enabled. I powered it up and the "HDR with a slash through it" popup was presented because the HDR Timer configuration had this time period setup to not use the HDR feature. The video resolution at the top of the screen still shows "2560x1440P(HDR)30FPS". I can't see any way to know if the HDR feature is on or off when using the HDR Timer feature (on screen or in the video status line).
