Vantrue JS3 Jump Starter & Air Compressor - Unboxing and First Impressions
Julian23
Germany
Several brands :)
My experience with the Vantrue JS1 over the last several months was very positive, so I was curious to see how their newer JS3 model stacks up as Vantrue offered me to check it out.
This new version is a 3-in-1 device combining a jump starter, an air compressor, and a power bank.
With a massive 3250A peak current, the JS3 is rated for up to 3.8L diesel engines and 8.0L gas engines. This means the widely used 3.0L diesels here in Europe will be absolutely no problem for this unit to handle.
Key Specifications
Jump Starter
  • Peak Current: 3250A
  • Compatibility: All 12V vehicles up to 8.0L Gas and up to 3.8L Diesel engines
Air Compressor
  • Modes: 6 presets (Car, SUV, Motorcycle, Bicycle, Ball, Free mode) with Auto-Stop function
  • Supported Units: PSI, KPA, Bar, kg/cm²
  • Display Precision: Down to 0.01 Bar increments
Power
  • USB-C Port: 65W Power Delivery (In & Out) for fast charging laptops, tablets, and phones
  • USB-A Port: Quick Charge 3.0 (QC 3.0)
Display & Lighting
  • Smart LCD: Real-time battery capacity, tire pressure, and live vehicle voltage display (when clamps are connected)
  • LED System: White light (Solid, Blink, SOS) and Red light (Warning flash, SOS)
Packaging and Carrying Case
The packaging is standard Vantrue. It is clean and informative.
The back provides all the technical specifications.
Opening the cardboard box reveals a very nice semi-hard carrying case. It has a small loop which can be used to carry it.
The case feels durable and is branded with the Vantrue Power logo.
Inside, everything is neatly organized. The top half holds the accessories in a mesh pocket, while the bottom half cradles the JS3 unit.
A closer look at the top compartment shows the jumper cables securely stored.
The JS3 fits snugly in its designated spot.
Build Quality and Features
Taking the JS3 out, the build quality feels solid.
The back of the unit lists the regulatory labels and the technical specs.
One of my favorite design choices is the cleverly hidden storage compartment right on the device for the air compressor nozzles.
It is a really clever solution so you do not lose those tiny valve adapters.
One side has both USB ports, the compressor outlet and the connector for the jump starter.
The less often used ports for the compressor and the jump starter are hidden with a flap.
More in the next post. (picture limit)
Opening the rubber flap reveals the ports. These hidden flaps are awesome for protecting the ports from dirt and dust.
The base of the unit has the threaded port to connect the air hose.
The JS3 has a 65W USB-C input and output, and a standard USB-A with Quick Charge 3.0 The 65W PD is ideal for fast charging mobile devices or the JS3 itself.
Powering it on reveals a crisp and bright color LCD screen. It shows the battery capacity in real time.
A unique and very useful feature is that it also displays the actual vehicle voltage when the jump starter clamps are connected.
In the picture the air pressure target can be seen. On the left of it is the current pressure.
Air Compressor and Performance Comparison
The integrated air compressor is well thought out. It features 6 preset modes like Car, SUV, Bike, and Ball, and it stops automatically when the target pressure is reached.
I just put the JS3 head-to-head in a tire inflation test against another popular combo unit that I also made a post about here on the forum.
While both devices inflated the tire at the same speed, the Vantrue was significantly quieter and much more pleasant to listen to.
Moreover, the Vantrue can display the pressure in 0.01 Bar increments, whereas the competitor only shows 0.1 Bar steps. That is a big difference in precision.
Like most jump starters, it includes a built-in flashlight. The light is bright enough for the night and provides nice indirect lighting for roadside repairs.
It also features multiple warning modes, including a red flashing light, a white blink mode, and SOS signals.
Accessories and Minor Criticism
The kit includes a braided air hose. However, I do have some criticism here.
The valve connector at the front of the hose cannot be rotated independently. This means there is a risk of twisting the entire hose awkwardly when attaching it to the tire.
The jumper cables themselves seem robust.
Looking closely at the clamps, they make a very good and firm impression. The copper teeth are sharp and should easily bite onto the battery terminals for a solid connection.
The controller for the clamps has clear indicator lights to guide the user.
The boost button can be used to revive completely flat batteries. Otherwise the boost button isn't needed.
The back of the controller includes printed safety warnings and a quick connection guide.
Initial Verdict
I have not had to test the actual jump starter functionality on a dead battery yet. (luckily) However, charging my phone, using the air compressor, and testing the lamp all work flawlessly.
Overall, the JS3 seems like a well thought out product. Vantrue clearly listened to user feedback. The combination of a powerful jump starter, an intelligent and precise air compressor with auto-stop, and high-speed 65W charging makes this a great all-in-one tool for emergencies or camping trips. Put it in the car and use it when required.
I have a small update after using the JS3 in a few practical scenarios over the last few days.
First, I used the unit to check and adjust my tire pressure after a wheel change. The process was very quick. The high precision of the 0.01 Bar display really shines in this situation. It allows for much more accuracy than the standard 0.1 Bar increments found on most other portable pumps. It is great to see exactly what is happening in real time. Using the JS3 was much quicker and more convenient than having to go to a gas station.
I also had a chance to test the actual jump starter function this past Saturday. I was at an event where an old BMW 3 Series had accidentally left its parking lights on for several hours. The battery was too weak to start the engine. I hooked up the JS3 and the car started right up on the very first attempt. The device handled the situation perfectly without any hesitation.
To jump start a car, first connect the clamps to the car and then plug them into the JS3.
The JS3 will turn on itself and display BOOST and the voltage of the car's battery.
The controller of the clamps will light up green if everything is connected correctly.
The last step is to simply start the car.
So far, the JS3 is performing exactly as promised and is proving to be a very reliable tool to keep in the car.
If you see my review, I made a video jump starting a vehicle. Worked the very first time on a dead battery! I would say the battery pack may be good for a few jumps before recharging is necessary. Still not bad at all. I can recharge the jump back rather quickly with a faster charger.
Yeah definitely good for a few jumps, I've had to do maybe four or five jump starts on friends cars over the last couple of years. These all pretty much work the same no matter what brand you use, but the first time ever using one is pretty cool to see how it works.
I used a Noco GB-40 before this jump pack was received. No air compressor so less handy. Pretty impressed with the JS3.
I should add my mom ran over a nail today. 11 PSI in the tire. Took about 3-4 minutes to inflate back to around 40 PSI. Compressor does a terrific job! Will need to refill it again so she can get tired patched. JS3 comes in handy!
The first time for me I was a bit nervous as I had the whole family watching because we'd just come back to the airport to find the car battery was flat. Thankfully it worked and didn't spoil the end of our holiday.
Lifesaver really in situations like that
Can you show how the clamp is connected to the heavy gauge wire? That is, the other end of the clamp.
The clamp looks like a quaility item.
Sure!
The copper cable is crimped to the clamp.
The crimped (folded) part that holds the cable is part of the clamp itself.
Here are two pictures from each side:
Sure!
Thanks for going to the trouble of taking and posting the images.
It looks like they are firmly clamped.
I asked becasue of personal expreience with jumper cables that had poor clamping and would not allow enough currnet to flow to the battery.
I ended up clamping down best I could and then solder them. That fixed the problem.
It was done a long time ago hehe.
The crimping seems firm. I don't think it would cause any issues, especially if taken care of and not pulled strongly on the cables.
I'm presuming the material on the inside is most likely copper?
It appears to be copper all the way.
I didn't see any other kind of metal in the clamp except for the spring.
Bought the Gooloo A3 this week, bit smaller battery size than this JS3 and doesn't charge nearly as fast, but the main jumpstart and inflator spec is pretty much the same. Impressive for something that's nearly a third of the price of the JS3.
What works best of course is a personal and financial decision. My Noco worked great, but I had a separate air compressor that required 12v socket and is extremely cumbersome. It came with my Volvo, along with a tire inflator kit that attached to the compressor. The JS3 the air compressor is so much better having a digital meter, shutoff, and ability to rapidly fill a tire . The Jump Pack works well, too. Yes, my Noco GB40 is spectacular, but lacking the air compressor is a huge drawback.
I imagine your Gooloo A3 does the trick just fine. So I wouldn't fret over cost savings.
Fair points but cost savings are good, especially when it offers similar functionality. It does beg the question though whether a brand charges double or triple the price of the competitors when they are sourcing it from same or similar ODMs....
Did you press the boost button during this process? The way I'm understanding it, the boost button enables a relay inside the JS3 which sends power to the jumper cables.
Also, I don't understand why the user manual says:
  1. When the car voltage is less than 9V,
    BOOST+current voltage will appear on the screen+
  2. At this point, press the BOOST button on the battery clamp, and the screen will change from BOOST to READY
It implies to press Boost only when the car voltage is less than 9V. But a car won't start below 12V so why do they even mention 9V? In your case it was measuring 12.0 V which would have required a boost which is enabled by pressing the button.
These jump starters all work the same. Boost function is only used when the battery voltage isn't enough, in which case the jump starter will display a message or a light won't come on or whatever.
If the engine doesn't start with not using the Boost button, then try again after pressing the Boost button.
