Rhody401
- Jul 29, 2016
Bottom Line: SOLID QUALITY PRODUCT WITH GREAT PICTURE
After using many other brands in the past, it was time to try the Vantrue N4 Pro 4k for a recently purchased 2024 Honda CR-V ST hybrid vehicle. I have heard very good things about the Vantrue brand, and the people were right. This system is like the "Lexus" of dash cams. I have the main kit/unit, the hard wire kit, the CPL lense filter, and the Vantrue branded memory card.
I installed this camera in August 2023, and have been using it for about 10 weeks. I wanted to use it for a while before posting a review.
The first thing I noticed is how well each item was packaged. The unit has some weight to it, and seems to be of high quality construction. The instructions are excellent, and it took no time to install the hardwire kit, and to run the cable for the rear camera. I tapped in to fuses #7 (Trailer) and #45 (Accessory), with the provided fuse tap kits. The hard wire kit included 4 different types of tap kits and related fuses, just in case. I mounted the camera to the right of the center mirror, as you can see in the pictures.
The app was easy to install and use, and I did a firmware update and was able to review footage from my phone. The memory card is hidden under a cover, on the side of the unit. The unit performed well in the heat of August. The buttons and menus on the unit itself are also very easy to navigate, and well laid out.
Some highlighted features:
Has the Sony IMX678 chipset, supporting Sony Starvis 2.0 tech
4k HDR front, 1080p rear and inside cams
Integrated GPS
Night vision
Voice control w/12 commands
Buffered Parking Mode pre records activity
5Ghz Wifi connectivity and app
OTA firmware updates
Supports up to 512GB memory card
Dual capacitors
G sensor
Magnetic mounting bracket for easy disconnect
18mo warranty
It also came with warning stickers, 11.5ft USB C charger cable, 3m tape, dust-free prep cloth, trim pry bar, 3.3ft USB data cable, 20 ft rear camera cable.
We are completely satisfied with this product, and will probably purchase a second identical setup for our other vehicle. I have peace of mind knowing that we are protected while driving, and also while the vehicle is parked. The picture quality is excellent, unit is solid, and the software is stable. The previous reviews I read about this camera were indeed correct!
Integrated GPS
Night vision
Dual capacitors
G sensor
18mo warranty
