leteus
- Oct 20, 2013
- United Kingdom
- Vico-WF 1
Hello all
Have just purchased and installed a Vico-WF 1, which I am quite impressed with, although the night capture is a little dark............which is why I wanted to install the firmware upgrade ver 1.47 which goes someway to correct this.
However, I have run into a problem..........The upgrade file has to be loaded into the cam via the micro SDHC
card..........problem is how can I transfer the file from my computer to the card, as it appears that win 7 64 bit doesn't recognise SDHC cards (16gb) as it tells me that the card has an unrecognised file system and wants to format it, but I am reluctant to do that as I'm not sure what file system it will format it to, NTFS or FAT 16/32 and I am assuming that the WF 1 probably uses FAT 32. I'm concerned that if it's NTFS and I load the card into the cam it might corrupt the cam, although that's just my assumption......... I also have a Nexus 7 tablet, which although I can add an OTG cable and suitable card reader, will only allow reading not writing!
Anyone have any clues or suggestions as to how I can sort this problem out.
Thank you
Thank you
