vvs49
- Jan 8, 2015
- Ukraine
I did not understand the question, sorry !!have you done a version of v1.03 but with just GPS enabled by default?
That's not an error! We changed the previous SD card icon to the current HE.Error in the latest firmware - icon when turned on H.265 codec, then download it, I fixed this!!
MY_FWA119V3_V2.6T_20211203_HDR_automatic.zip
drive.google.com
If you replace the icon with a pretty girl?SD card icon to the current HE.
Of course everything is simple there!I was wondering how easy it would be to change that behaviour to set GPS to enabled by default.
This statement is controversial, I do not like these meaningless letters and not only me, so I took it for a mistake !!HE means High Effiency which is a correct icon solution for H265 encoding (HEVC) instead of an SD Card icon.
That video comparison is so poor because make people believe that 60FPS is better than 30FPS.Definitely HDR is bad for day, but it's magical for the night.
Viofo -" Jak sprawdziliśmy po naszej stronie, wszystko jest w porządku dla V2.5 20210715, zarówno parkowanie, jak i wideo z jazdy golą 2880x2160 P30" ktoś mógłby sprawdzić?
The Link does not work for me (no option to download it, permission problem), can you re-upload it? I would like to try out the timebased automatic hdr on/off setting.A test firmware has been released from VIOFO in which the time for turning on and off the HDR is set.
The timing is in the HDR section of the menu !!
Checking, letting us know our impressions !!
drive.google.com
This type of HDR supported by the CMOS was created for CCTV cameras or other (industrial) cameras which are recording in a fixed position.@VIOFO-Support The only other thing I can think of wrt. the bad DOL HDR quality while in motion is to store two video files at the same time: one with low exposure and one with high - is this supported by the chipset in theory? That way you can look up the license plates during night by opening the low exposure file alongside the high one. By doing so the problem of not being able to correctly digitally overlap the low and high exposure frames is mitigated.
