I want 2.6 firmware with wdr.old wdr firmware not stable.( Sunlight)If you don't like the HDR feature, install a firmware that has WDR. Firmware with WDR enough on the Internet.
viofo sended message. use old firmware.Not possible.
If you want WDR then you need firmware 1.03 (which is what I'm using)
She does not work at night, everything will be illuminated.If you want WDR then you need firmware 1.03 (which is what I'm using)
I suggested to make a firmware for Viofo, so that HDR is on / off. from the button, then in your case, turning off the HDR during the day will not be blurry !!I very rarely drive at night so that bit isn't important.
That's right, to each his own!!All in all I'm happy with 1.03 as it's doing what I need.
I am in a similar situation. I will try new firmwares now and then but always come back to 1.03 build 20190911. I will probably try 2.6 just for the hell of it but will not be surprised if I go back to 1.03. I just wish there was a way to save all the settings on an SD card so I do not have to navigate that menu all the time.All in all I'm happy with 1.03 as it's doing what I need.
No, just a few minutes it is a first world problem for sure but the Dashcam is tucked away tight behind the rear view mirror to be inconspicuous and so is not easy to get to or to see the screen. I do not like all that button pressing and inevitably press the wrong button now and then. It is a small PITA but still a PITA particularly in our climate and enough to be a deterrent to experimentation with settings e.g. parking mode with an external USB power pack or new firmware.. My dslr allows me to save settings to a card and it would be nice feature if the Dashcam had the same.Does it take you too long?![]()
Yes, it's a bit inconvenient to do it on the spot.No, just a few minutes it is a first world problem for sure but the Dashcam is tucked away tight behind the rear view mirror to be inconspicuous and so is not easy to get to or to see the screen. I do not like all that button pressing and inevitably press the wrong button now and then. It is a small PITA but still a PITA particularly in our climate and enough to be a deterrent to experimentation with settings e.g. parking mode with an external USB power pack or new firmware.. My dslr allows me to save settings to a card and it would be nice feature if the Dashcam had the same.
For best picture qualityYes, still using 1.03 on both my V3's
Which settings in particular are you looking for ?
Any reason for the 5 seconds startup delayI've just edited my last post with the main ones
