Samsung:
Fairly confident as it both states on the product and after contacting support. I'm sure if you ask nicely that it'll be fine but I don't like the fact that it can be taken away. I've seen some reports where you can cut the SD card and send it back if you tell the rep you are worried about privacy (Sandisk).
Me:
Could you clarify the length of the Samsung Pro MicroSD Card - MB-MG64EA/AM when used in a dash camera? Under the full specs it says 10 years but it has an asterisk that says "Warranty is limited for any type of surveillance system."
Samsung:
Samsung SD Cards and Micro SD Cards are not intended to be used for continuous recording purposes for example, in surveillance systems such as a car-black box. The reason for this is because the card may fail with constant and obsessive reading and writing. They are not designed to be constantly and continuously written to.
Me:
Hi, that makes sense, does that mean there is no warranty on these cards when used in a dash camera?
Samsung:
It would be a case by case basis. If the card would fail within its warranty period we would have to review the case.
Lexar 633X
I'm confident the Lexar 633X 128GB card is MLC. Two sources:
1) From
Our Berries Review
2) Direct from Lexar Support. They said MLC and SLC. I thought they made a mistake but from another customer rep they said SLC as well. Don't know what to think...
Lexar:
Thank you for contacting Lexar Support. Unfortunately, we have many different manufacturing plants and they could use either MLC, or SLC NAND. Most of the time they are MLC, however some manufacturing plants still use the SLC parts. I can only guarantee the speed rating. Your 128GB 633x carry up to 95MB/s read, and 20MB/s write speed.
The 633x card does carry a limited lifetime warranty. You can safely use it within a dash camera or surveillance system without voiding your warranty. You would need to check with the manufacturer, as some devices, particularly older devices may not support capacities this large.
Me:
Just to clarify do you mean MLC and TLC construction for the 633x? Getting SLC would be awesome as a consumer but it might be expensive for Lexar.
Lexar:
That's correct. There are some of the 633x cards that are MLC and SLC design. Our 633xcards have been known to be a great card for dash cams and small cameras. I hope the information has helped.
