Specifications: | |
Model | Mobius Maxi 4K Camera (MM4K) |
Angle of View | Lens A: FOV 150° (Diagonal), wide angle, f/2.8 |
Video Resolution | 4K 30fps /2.7K 30fps /2.7K 60fps /1440P 30fps /1440P 60fps /1080 P30fps
/1080P 60fps /1080P 120fps /720P 120fps /720P 240fps |
Video File Format | MP4 / MOV |
Video Codec | H.264 / AVC |
USB Interface | Type C (USB2.0) |
TV out (Video) | PAL / NTSC |
Memory Card | MicroSD memory card (not included in standard package)
Supports FAT32 and exFAT, working with larger cards, 512GB tested
Note: 4K 30fps, 1080P 120fps and 720P 240fps requires U3 or above |
LED Indicator Light | Red, Yellow, Blue, Green (can be turned off when needed) |
Buzzer | Supported (beeper can be turned off when needed) |
Microphone | Supported (Audio can be muted when needed). |
Dimensions | Approx. 72mm x 35mm x 18.5mm (Lens diameter 20.5mm) |
Net Weight | Approx. 50 grams only, with capacitor included. |
Power Input | Standard USB DC +5V (Recommended Charger 2A or above) |
Internal Battery | It's a capacitor version, has no battery inside. Needs to work with external power |
Working current | Max 412mA@ DC 5V, Max 490mA@DC 4.2V |
Photo Mode | single, burst and time lapse modes; JPEG |
Long Exposure Photo | Supported (1s; 2s; 5s; 8s; 30s, 1minute) |
Motion Detection | Supported |
Loop Recording | Supported |
Auto Record | Supported, auto start when connecting to external USB power supply |
G-Sensor | Supported; Auto save and lock Event video files; auto flip video. |
Advanced IQ Settings | Supported. Can set Exposure, AE metering, Contrast, Sharpness, AWB |
Video Image Stabilization | Supported (EIS) |
