VIOFO A119M Pro_FIRMWARE
If you would like to know more, feel free to ask the manufacturer's support team:
In principle I don't think that should be necessary, but thanks for the link. Changelogs should be informative in of themselves. If they've chosen not to be descriptive in public, I have no reason to believe they will provide me more details.
A119M Pro 한국어 지원해주세요.
제가 대한민국에서 VIOFO 홍보를 엄청나게 하고있습니다. 다른 모델은 한국어가되는데 A119M Pro만 지원이안됩니다.
Please support Korean for the A119M Pro.
I am doing a lot of promotion for VIOFO in South Korea. Other models are Korean-speaking, but only the A119M Pro does not support it.
When significant changes are made to the firmware and new features are added, the manufacturer provides detailed descriptions.
1. Add supporting enable / disable 'Rear Camera'.
2. Optimize G‑sensor sensitivity for parking mode.
3. Add 'Parking Only' option for Audio Recording.
4. Other bugs fixed, GUI and UX improvements.
Where can I download this? The official website doesn't have the A119M Pro listed at all anymore
It’s possible the new firmware has an issue, I’ve had my dashcam stop functioning twice since installing the latest firmware. Needed power cycled both times.
Welcome to the club @yrkhsn
VIOFO OTA Firmware Updates are currently down.
Official VIOFO website page containing firmware updates is also down.
I’m sure they’ll be back up soon.
In the mean time, if you want to update with SD Card method I downloaded the official firmware when I updated my A119M Pro 3 days ago.
Here’s a link to the firmware in a public Google Drive Folder;
VIOFO Official Firmware - A119MP V1.2_260817
https://drive.google.com/drive/folders/1PYDtahvzGraWRVv8ucprm17yp7nnh4M4?usp=sharing
I updated 3 days ago, and have not experience any malfunctions.
If you are experiencing a malfunction #1 & #2 cause is;
1.) Power Starvation
2.) Incompatible SD Card
1a.) Please try original VIOFO brand car charger & USB Type-C power cable included with camera box to check.
2a.) Please try using VIOFO RECOMMENDED SD CARD
If you are already using VIOFO recommended SD Card please perform a “Deep Format” with the VIOFO RECOMMENDED DEEP FORMAT TOOL
Last week my A119M Pro indicated a firmware update was available, so I did an OTA update that completed successfully. It was the v817 FW and didn’t require a reset. Today, my Dashcam indicated there was another FW update available. I didn’t check the version of the new FW, thinking it was an urgent bug fix to the v817 FW update from last week, so I performed the OTA update. It reset my Dashcam, so I had to reenter all my settings. I checked the FW revision and it said it was v817. Very strange. I’ve no idea what’s going on with this update.
I’m having issues with the camera not starting up all the time since I updated to the latest firmware. When that happens, I have to start it manually. Anyone else seeing this?
Welcome to the club @Gymbow
See Post #66
I updated 8 days ago, and have not experienced any malfunctions.
-Chuck
Thanks for the suggestions Chuck. I’m using all Viofo accessories, including cables, HK6 and SD card. And I did a format after the camera was reset post update. I have the HK6 set to 12.4V. I suppose there’s a possibility the camera might not have started up due to low battery voltage on the vehicle.
