dirkzelf
- Nov 16, 2012
- Netherlands
Thanks! Did you use the AV out port into a monitor or HDTV to focus?
WAIT, WHAT?? It has AV out???
Is the video output good enough for focusing?
I dunno... haven't got the cable, so.... depends on AV OUT resolution .... if it's 720p, it should be.
I've wanted to try the telephoto's on the A119 and A119S for a while now and with the new 8 and 12mm being so much better than the previous ones, I wonder how they'll look with these two cameras, especially the A119S.
Nice set up! I could hook it up to my television but the maximum distance I can focus indoors is 25 feet. Not going to invest in a portable screen just for focusing, will stick with the Mobius cams.
Out the window won't work as from the lower floors all you can see are houses and higher up only treetops (right outside the window). I focus the Mobius cameras from the balcony or from the terrace/roof.
What's that like? 720, 480? What cable do I look for?
This one? 3.5mm to tv cable.
Yes, all AV cables are not wired the same. Here's a link to a thread with wiring info for the A119: https://dashcamtalk.com/forum/threads/video-cable.21275/#post-298099. You can google for cables compatible with the Apple ibook AV cable. Others will work if the inner pin on the 4-pin 3.5mm plug (ground) is connected to all the RCA plug coaxial shields. I have the actual Apple cable. It is wired correctly but the backshell was too big to fit the depression around the A119 AV output jack, so I had to modify it.might work, they're not all wired the same unfortunately, as long as you have the plug and some cables you can always rewire it if need be
fix a drop of nail polish
