Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
If used as a single camera with no rear camera connected then it can do 60fps.From what we were told here, no, 1080 30fps front and back is highest it’ll do.
The a129 will have the sensor from the a119s front and rear but it’ll record 30fps and have no 60fps option like the a119s because of the dual channel set up. Again, this is just what we have been told on here thus far. Basically it’ll have good night quality as that’s where the a119s excels.
Resolution is less than A119 or A119 Pro, so if you are trying to read number plates then they will need to be closer, however having a more sensitive sensor it can use faster shutter speeds meaning less motion blur so plates are readable at closer distances than they would be on an A119. Same situation as with the two A119S, except the recordings go onto one SD card and it has wifi.
