To further answer your question we recommend 3 hour cutoff timer and low bitrate. We find most people will never have any issues with those settings.
Oh, thanks for the clarification, my battery is lead-acid.
I'm not very familiar with electronics, you've probably figured that out!
Tonight I'll try to check the current battery voltage with Carscanner via OBD with the ignition off.
Anyway, the limit values should be those reported by @jsmith .
From what you say, I need to set the voltage cutoff in the HK6 kit and on the camera to 12.4V, while on the camera I need to set the cutoff time to 3 hours.
Regarding parking mode, do you suggest setting it to low bitrate recording (continuously for 3 hours), or Hybrid Parking Recording with Low Bitrate and Impact?
@jsmith , the 3-hour limit is subjective, it depends on your habits. At work, I'm safe and don't need to record, while most of the time I park in the city center, 3 hours is enough for me.
If I need to record an entire day, then I need the external battery; I can add it later.
I'm taking it one step at a time 🙂
