Back to my review...
Battery Discharge Testing - Low Bitrate Parking Mode
My car is a hybrid with a small 12V battery. My drive to/from work is about 10-15 minutes and I park at the office for 9 hours - not ideal for the long-term life of the car battery. I'm probably an ideal candidate for using a dedicated dashcam battery, however I wanted to test the A329T with my car battery first before taking that step.
Before the A329T, my primary dashcam was a 2CH A139 connected to an HK4 at 12.0V cut-off, and I noticed that the A139 frequently shut off during low bitrate mode (LBR) when parked at work. The A329T combined with the HK6 supports hybrid parking mode and I was interested to verify that this could extend parking coverage to the whole day.
Before testing the hybrid parking modes, I wanted to get a clearer picture of my car battery voltage throughout the day. The A329T can show the voltage reported by the HK6 in the OSD text, so I tried using this to monitor the battery over time. It was cumbersome to review hours of LBR video and enter the voltage values into Excel, but I did get some results that showed the voltage dropped to 12.0V around 7-12 hours, on a good day.
I soon found that using the HK6 was not a practical way to monitor the voltage over an entire day, and it was difficult to interpret the parking mode results without the context of seeing the periods of battery charge whilst driving. I spent a while trying to find a non-intrusive way to monitor the battery over time. Eventually I found what I was looking for in a battery-related discussion here on DCT: a
BM200 bluetooth car battery monitor that logs the battery voltage every 2 minutes and saves the data for up to 70 days, with a companion app that can show real-time voltage with 1Hz refresh and an all-day voltage graph.
Here is a screenshot from the BM200 battery monitor, overlaid with my own annotations, showing 8.5 hours of low bitrate parking on a day where the resting voltage was high prior to commencing parking mode.
- I note that the battery voltage recovers by about 0.1V when the load is removed as the HK6 shuts off.
- I can also see that the voltage reported by the HK6 is slightly higher than the BM200. The voltage at cut-off according to the BM200 was 11.89V.
The following day I made the short drive to work then left the A329T in low bitrate parking mode. As shown in the graph below, the HK6 reached the 12.0V cut-off after only 2.5 hours. Later in the day I took another short drive, after which the battery dropped to 11.93V in just 2 hours of parking recording.
Summary
For my car, the available recording time in low bitrate mode is highly dependent on the State of Charge (SoC) of the car battery. It may also be affected by the ambient temperature, something I did not log in these tests.
- The SoC is affected by durations of driving (charge), parking (discharge) and overnight (at rest), and presumably temperature as well
- If I keep the HK6 cut-off at 12.0V, I am unlikely to achieve 9 hours of low bitrate parking recording to cover a whole day at work
- I'm not particularly concerned if the BM200 and HK6 report slightly different voltages, provided that each device is consistent. I can adjust the HK6 cut-off up or down if I want a shorter or longer parking duration.
My next post will show the effect of using Hybrid Parking Mode on the A329T to extend parking coverage to a full day, and beyond...
