VUEROID S1-4K Infinite_FIRMWARE
The Vueroid HUB app has been updated.
You can read about the new features at the link below:
Immediately after the app update, the new firmware for the S1-4K (V1.4.2) will be downloaded.
the major change is as below
*firmware
- video quality is enhanced ( IPC mode )
- HDR timer for IPC mode
- privacy mode added ( turn off / on , inner cam and audio , using long press view mode key
- Added low power mode entry time "auto" option.
: check the battery level pre-configure power off voltage, and change to ELPM mode automatically.
=> just set the power off battery level and set it "auto", S1 will working normal parking and ELPM accordingly .
- fixed Varios minor bugs.
- GPS strength check menu added.
*Hub app
- streaming transcoding function added ( normal , low) : live streaming and VOD
- Timesync with mobile function added. (HUB timezone setting
- VPN detection popup on Hub
- Cam installation guidance is added on Hub
- rename function added
- more stable wifi connection.
- live view map control advanced
- ETC bug fix and UX is advanced
My previous settings (FW V1.4.1):
- 1 Hour of normal parking recording, then automatically switch to Extreme Low Power Mode (ELPM)
- Dashcam power off at 11.7V
My new settings (FW V1.4.2):
- ELPM entry time set to Auto
- Power Off Voltage increased to 12.0V
-- I assume the S1 will record in normal parking mode until the voltage is 12.0V, then automatically switch to ELPM
-- Without a second cut-off voltage, will the S1 remain in ELPM forever if I leave the car parked for a few weeks??
Yes.
The power consumption in both Power-off mode and ELPM is identical at 1 mA/12V. Aside from ELPM waking up due to an external shock, I am confident that the probability of battery discharge caused by ELPM is extremely low
That is an impressive figure of 1mA My Camry (Aurion) is reported to draw 20 - 50mA! And that is when it is parked and gone into sleep mode
I would think the Camry powers more sensors and functions in "sleep mode" than a dashcam does, though. Subaru Outbacks run between 20mA and 70mA or so. Of course, this depends on how many gizmos are on the Outback.
Setting the horizon according to the new live view guide line in the HUB app (approx 70% sky : 30% ground)
View attachment 90145 View attachment 90144
when we designed the S1, our most focal point was. the following product will have same feature, and in terms of engineer side , it's most difficult point to implement
When you set a high bar, even if you are all that, often it is anything but easy to keep the bar up there.
But one should of course try, CUZ the people putting the bar anywhere lower, well plenty of those.
Thanks for the extra data on the Subaru.
That was exactly my point when I mentioned the Camry's 20-50mA draw—it’s interesting to see how much more a car's sensors and functions consume compared to such an efficient dashcam.
There's some well thought-out features in that release, the horizon line and sync GPS time will be very useful to installers, the other changes seem to all be positives (to me as a non-owner), sometimes you read the details of firmware releases and think 'why did they do that?' - not just dashcams either.
That's good news. Sorry for our mistake again.
Apologies I missed your reply. No problem at all; firmware OTA upgrades can be tricky, with users on various different versions and many permutations of upgrades. What is most appreciated is how fast the small bug was fixed.
We've already added a 2nd Vueroid S1 4K-3CH to a family member's car and are planning for a third S1 4K Infinite in a relative's car. And the latest 1.4 firmware installed without a hitch on both. If / when my old Blackvue dies, it will be an easy choice.
Version: v1.5.5
    • Improved Low Power Mode wake-up stability.
    • Improved recording transition stability between Parking Mode and Continuous Recording.
    • Fixed ACC/DC Out operation issue when no SD card is inserted.
    • Added a log message when entering ELPM due to low-voltage cutoff (SLEEP-LOW VOLT).
    • Fixed an event recording error when changing Privacy Mode via key operation during Live view.
    • Fixed an issue where timelapse videos stopped before reaching the end during playback.
    • Fixed a mobile VOD timelapse seek issue.
    • Fixed and improved VOD streaming issues.
      : Fixed A/V sync issues, fixed timelapse issues, and improved video mosaic issues.
    • Fixed an issue where the Recovery popup was not displayed and Key operation /
    • ACC, DC Out functioned incorrectly after skipping the initial popup when using high-capacity SD cards.
    • Improved reboot delay time after mobile firmware update (reduced by approximately 1–5 seconds).
    • Updated OSD display text based on the current ISP setting (Normal, HDR, IPC).
    • Simplified “HDR+IPC” to “IPC” in the Video Enhancing menu.
    • Changed factory reset SD formatting voice guidance to follow the selected language setting.
    • Added 6 new cities/regions to the Time Zone settings.
    • Updated the “SD Need Format” voice prompt.
    • Added new language support for German, Italian, and French, along with updated voice guidance.
    • Corrected Spanish typos and updated 4K60P-related popup messages.
    • Improved ELPM functionality.
      : Added a new Hybrid Mode to ELPM.
In the latest V1.55 firmware, there is a new option under Parking Recording Type for ELPM called Hybrid Mode. Anyone knows how does this work? It was defaulted to OFF. It was set ON before the update. I usually let my dashcam continue to record with Impact + Motion when parked until my power pack battery voltage drops to a pre designated voltage, after that it will switch to ELPM. How different will the hybrid mode be ?
Hi there,
It's really great to see you here. We've been talking through DMs for quite a while, so stumbling across your post here was a pleasant surprise.
You can pause the video and refer to the table that explains the different parking mode configurations.
Let me know if you need more.
Have a good day~
Thanks for the reference video, now I am clear on what setting to use for my needs.
It's nice to see a rep from the product company that has a presence in the forum. It helps to clarify any queries or doubts, thereby reducing the no of repetitive questions from consumers.
I can say with certainty that the after sales service from Vueroid is exemplary. Not every dashcam maker will go the extra mile to support their end users.
Thank you !
Hi there,
Have a good day~
Version: v1.5.6
  • Fixed a START-ERROR issue that occurred when configuring Infinite Plate Capture (IPC) and HDR Timer Settings.
  • Fixed an issue where the LCD would not turn off under certain conditions.
  • Fixed an issue where button inputs could be ignored in specific situations.
  • Fixed an issue where the firmware version information overlapped when Italian was selected.
  • Corrected German popup text.
  • Fixed Spanish localization errors.
  • Fixed an issue where 60fps VOD recordings stopped playing at approximately 57 seconds in the mobile app.
  • Improved Hybrid Mode and Power-Off Voltage thresholds.
  • Disabled audio output when entering Low Power Mode via Hybrid Mode settings.
  • Extended Parking Event Notification duration from 10 seconds to 30 seconds.
  • Added TB (terabyte) capacity display to SD Card Information.
VUEROiD S1-4K Infinite Firmware Download Page
Version: 1.6.0 - Release Date 07-Sep-2026
  • Improved mobile app connection stability.
  • Updated voice guidance to remain active when Speaker Volume is set to “OFF” in the Favorites menu.
  • Fixed an intermittent issue where rear-camera recordings were saved as 0-byte files in the F+R configuration when the interior camera was disabled during parking mode.
  • Fixed an issue when switching channel configurations through the mobile app.
  • Fixed a Wi-Fi pop-up display issue after a connection timeout.
  • Improved video streaming and playback performance.
  • Improved overall system stability.
NOTICE
Before updating the S1-4K Infinite firmware via SD card, please update the VUEROID app to the latest version.
HUB app versions as of 07-Sep-2026:
  • iOS 1.6.0(257)
  • Android 1.5.17[242]
If you use the VUEROiD HUB app to update the firmware version to 1.6.0, make sure you update the HUB app to the latest available version of the HUB before attempting to connect to the S1-4K Infinite dash camera.
As of 07-Sep-2026, this firmware update is flagged as an important/forced update by VUEROiD, so you will not have a choice whether to download the update to your phone and then send it to the S1-4K dash camera.
