patrick0525
- Oct 30, 2015
I plan to mount on the windshield black-dot area. What 3M product should I use without damaging the block-dot area after one year in the sun. Thanks
I've used it and had no issues getting it off. I can't remember if it left any residue or not but if it did there wasn't much and it cleaned up.https://www.amazon.com/gp/B00JDT0HV6
Does the adhesive of this product works the same way as 3M VHB tape? Non-damaging to the windshield black-dots? Has anybody tried removing it ? Does it come off cleanly as VHB?
That might be a down side for some people I did forget about that.The problem with the dual-lock tape is the black version has a white backing where the adhesive is and it's very visible
The problem with the dual-lock tape is the black version has a white backing where the adhesive is and it's very visible from the outside if you mount it on the glass.
Not talking about the release strip but the actual adhesive strip itself. All the black dual lock I've seen in the stores has white adhesive - if I could find it with black I'd buy it in bulk.I'm puzzled about this comment. All the black Dual Lock tape I've ever purchased has a black adhesive. Some versions do come with a white protective release strip covering the black adhesive that is removed before installation. Why is this a problem?
Look at the Amazon link in the above post and you can see where the backing on the 'knobby' stuff is white.
I don't doubt that. Unfortunately it seems that all retailers around here choose to sell the white backed version....Locally, Target, Walmart, Walgreens and three hardware stores in my area sell black Dual Lock tape and all of these come with black adhesive.
Haven't looked in Walmart and haven't seen it in the others. Seems that only hardware type stores carry it around here - ACE, ACO, Home Depot, Lowes, etc. A Menard's just opened not too far from me so I may take a look there.Even Walmart, Walgreens and Target?
Last time I looked (maybe 4 months ago, at Home Depot for that matter) it was either clear with clear adhesive or black with white adhesive....Are you sure you can only find it with white adhesive?
My Walmart is white backing. That's where I got what is in my front windscreen.Even Walmart,
Can I eject the camera from the adhesive mount? | G1WX | 3 | ||
R | G1W adhesive mount | G1WX | 2 |
Similar threads |
