Keiran Gilmour
What are the Different Types of Laser Measures You Can Find?
The laser tape measure is so efficient that all you have to do is to point it unto the surface of your target and it will automatically give you the distance to that point. The best laser tape measure is the one that offers the most convenience and can measure different ranges, not forgetting the need to be sturdy and durable for long-lasting usage from one day to another. There are different kinds of laser measures around, and you must be aware of these.
✬✬✬ Find Out More: Best Laser Tape Measure: Ultimate Laser Measure Reviews
The DIY Laser Measures
There are two types of laser measures, these are the DIY home laser types and they are designed for simply renovation or remodeling jobs within a small property. They are relatively inexpensive and non-complicated devices that can measure and calculate accurately the distances between surfaces and even the volume and area of the target. These are laser measures that come with very few or no accessories. In most cases, the maximum DIY laser measures can measure a range of 60 meters. These devices don’t come with advanced in-built features found in the advanced laser measures. You will probably start with a DIY laser measure as a beginner. In many cases, the accuracy of a typical DIY home laser measure could vary from +or- ¼ inches to +or-1/8 inches
Advance and Mid-Range Laser Measures
If you work in the professional fields like construction, plumbing, building, architecture, and science, you will probably need more than a range of 60 meters to measure with your laser measure. In addition to a wider range, you will need a laser measure with multiple functions, versatility, and higher accuracy for measurements. The high end and mid-range laser measures are designed towards helping professionals handle outdoor and indoor measurements with the utmost professionalism. You can find mid-range laser measures with more than 300 meters of range. These laser measures also come with a wide range of accessories and in-built features for more accuracy.
Common in-built features you can find here include; in-built LCD screen that provides light in dark environments and also produces a sharp display of your measurements. Other features include; Pythagorean volume and area calculation, ability to switch the measurement from inches to meters and feet, and auto switch-off feature that turns off your device when there are no activities for a long time. Normally, mid-range and high-end laser measures cost more because of the advanced features they possess. It is possible to find some advanced features in the home, DIY too, despite their limited capabilities. The IP54 water and dust resistant features for instance are common features found in both DIY and advanced high-end laser measures. You can also find a carry pouch, or bag included in such packages.
Whether you use the home DIY or advance and mid-range laser measures, you will have to invest in certain accessories to achieve your desire. The top rated laser tape measure has a limited number of accessories that can be included.
☞☞☞ See Also: Top rated laser tape measure - Best laser measure for the money
What are the Benefits of Using Mid to High-end Laser Measures?
Just before the development and launch of a laser tape measure, the manual tape measures were used in measuring the distance and it was discovered to come with many flaws and limitations. The accuracy of laser measures is their number one benefit. Many of these devices can provide accuracy of up to 1/32 inches which is near perfect, and you can never get close to this accuracy when you use manual laser tape. All you have to do is choose a setting, then point the laser at the surface before clicking and you will see your result displayed on the screen of the measure. It is also possible to choose the units and toggle in-between measurements and that means zero chances of misreading.
Another benefit of using laser measures is that they offer multiple calculation modes. They do come with their internal calculators that can resolve complex calculations in a matter of seconds. Depending on the brand and model you choose, you can set the measure to beam and create a sound for the numbers. These devices will save you the time for writing down numbers and working them out manually and that will also save you the risks of miscalculating.
One benefit of laser measure you should consider is that it helps you store your previous works. Since working out the numbers is what you need to move to the next stage, you can store your data in groups of 10, 20, and 30 and retrieve them at any time. Even when you forget the numbers, you can always go back and retrieve them, to fill in the gaps while working. The in-built memory of your laser measure will remove the need to keep going back to check the accuracies of your figures.
In-field features such as Bluetooth are features you will appreciate on your laser measures. They can send your data to your mobile device, including smartphones and computers. This means you can share your information with other people on the project team. Some measures will allow you to take and send pictures of your measurements or even convert from one document file to another, thus facilitating the effective transfer of information.
Cost-effectiveness is one of the benefits of the best laser measure. With your laser tape measure, you don’t have to hire people for some other jobs, hence you can become a one-man team. With a laser tape, for instance, you may need someone else on the other end to help you hold the device on your target. With the laser tool, you can easily survey an entire area and send your figures for interpretation and this is more convenient, and faster than the manual conventional means. You will be surprised by the amount of money you will save by choosing a laser level. The article Which is the best laser measure - Complete laser tape measure reviews
will give you more insight into choosing the best laser tape measures for your needs.
![8FQ4q7U.jpg](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F8FQ4q7U.jpg&hash=daacecc196391d5377ffcc585c8c19e8)
![X6f5wTh.gif](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FX6f5wTh.gif&hash=a8bc3571aea0126aca314b30a32aa686)
![ptLldC4.jpg](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FptLldC4.jpg&hash=355a99c4f3035306bb6afd3c0cd4b4b5)
![5gsJfRS.gif](/forum/proxy.php?image=https%3A%2F%2Fi.imgur.com%2F5gsJfRS.gif&hash=087401b8cd648b6ea7a6c99eb910e82b)
