egonvdv
- Aug 9, 2013
- A Dutchy in the South of France
- France
- TWO Thinkware's U10002CH (rear cams used as side cams)
noticed at startup it would give the "on your smartphone connect to wifi" message,
which shouldn't be played, as i'm in hotspot mode.
Then tried to connect with my phone, but got "password incorrect" (it definitely was correct)
only option left was to reset camera (hold mic & record button until 5 beeps are heard)
this fixed the problem, but after having reset my setting, i ended with switching from 2.4 to 5.2gh
camera restarted (normal) but then again, it said "wrong password"
so had to reset again.
did all the settings.. again, except for switching to 5.2gh.
all is setup as before, including the hotspot connection, but clearly something's not right
Could it be the heat... or is the wifi starting to become defective... ?
I know it an be a million things, but pleased to hear if anymore here has had the same problems
