dirkzelf, well.
I would like a few tiny things changed from the current mobius, minor upgrades and tweaks, that about it.
* 2k at 30fps if you need to and then 1080p 60fps, heat issues will not be a problem with the newer chips out there
* Perhaps a tiny clock battery to keep the time and date correct ?
* Support for 128Gb MicroSD cards, if that is still with FAT32 does not bother me even though exFAT is better.
* Digital image stabilization, like with the gitup2 or similar products, a must in any modern action camera.
* Two high quality microphones so you get stereo sound, would be nice, and a cheap thing to add, there is
only one in the current mobius, you could add a additional microphone somewhere in the unit, seems to be
possible without to much trouble.
* Some sort of tiny connector on the IC-board so you can use a external microphone, and having the option to select internal
microphone or the external one, depending on the situation. You will probably need a custom cable but you still need the
connector on the IC-board, this way you do not have to mess with the built in microphones.
* Rotating the ribbon cable connector 180 degrees, and extending the ribbon cable to the sensor and lens so it is a semi round
cable with a little cable loop inside the unit, enough length to be able to move the lens housing 90 or 180 degrees and having
it in a fixed "seating", so it is nice and secure in the housing once you have shifted the lens to the new position. This will
allow anyone who want to use the unit upside down or sideways (like on a motorcycle helmet) to just move the lens to the
fixed position. Some sensors do not allow you flipping the image. A simple thing to fix but will have a great impact on
how you can use the camera. (A bit like the current extension cable and lens out there that you can buy if you want to move
the sensor outside the housing).
The most important thing is that the design, size of the unit does not change, then you can continue to use all the
extra addon things out there, FPV cables, custom cradle and so on. Otherwise the FPV cables does have everything you need,
basic video out, audio out, charging. But no microphone input.
