/etc/init.d # mount
rootfs on / type rootfs (rw)
ubi0:linux on / type ubifs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=18816k,nr_inodes=4704,mode=755)
none on /dev type tmpfs (rw,relatime)
proc on /proc type proc (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
tmpfs on /tmp type tmpfs (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
a on /tmp/fuse_a type fuse.a (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
1 on /tmp/fuse_d type fuse.1 (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
z on /tmp/fuse_z type fuse.z (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
a on /pref type fuse.a (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
none on /sys/kernel/debug type debugfs (rw,relatime)
tmpfs on /var/www/live type tmpfs (rw,relatime)
tmpfs on /var/www/mjpeg type tmpfs (rw,relatime)
1 on /var/www/DCIM type fuse.1 (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
574 root 0:00 [mtdblock11]
579 root 0:00 [mtdblock12]
584 root 0:00 [mtdblock13]
596 root 0:00 [ubi_bgt0d]
608 root 0:00 [lkvfs_bh 0]
651 root 0:00 vffs /tmp/fuse_a -l a -o big_writes -o atomic_o_trunc -s
654 root 0:00 vffs /tmp/fuse_d -l d -C 1 -o big_writes -s
657 root 0:00 vffs /tmp/fuse_z -l z -s
672 root 0:00 ombra
678 root 0:00 amba_mq_handler
679 root 0:00 /usr/bin/AmbaStreamSVC
681 root 0:00 /usr/bin/lu_lnxfio_stream
685 root 0:00 /usr/bin/amba_qrconfig
695 root 0:00 [kworker/0:2]
696 root 0:00 [cfg80211]
722 root 0:00 [mmcqd/0]
742 root 0:00 telnetd
745 root 0:00 network_message_daemon
759 root 0:00 cgiBridge
825 root 0:00 [wl_event_handle]
829 root 0:00 [dhd_watchdog_th]
830 root 0:00 [dhd_dpc]
831 root 0:00 [dhd_sysioc]
832 root 0:04 [ksdioirqd/mmc1]
879 nobody 0:00 dnsmasq --nodns -5 -K -R -n --dhcp-range=192.168.42.2,192.168.42.6,infinite
956 root 0:00 cherokee-worker -a -C /etc/cherokee.conf -j -s -d
1208 root 0:01 -sh
1854 root 0:00 [sh]
1855 root 0:00 ps fax
1856 root 0:00 more
/etc/init.d # netstat -pltn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:7878 0.0.0.0:* LISTEN 745/network_message
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 956/cherokee-worker
tcp 0 0 0.0.0.0:8787 0.0.0.0:* LISTEN 745/network_message
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN 879/dnsmasq
tcp 0 0 0.0.0.0:23 0.0.0.0:* LISTEN 742/telnetd
netstat: /proc/net/tcp6: No such file or directory
#enable Network daemon
[ -x /usr/bin/ombra ] && (ombra > /dev/null 2>&1)
#enable Webupload daemon
[ -x /usr/bin/dvf2web ] && dvf2web --daemon
#enable AmbaStreamer
if [ -f /usr/bin/AmbaStreamSVC ]; then
/usr/bin/AmbaStreamSVC &
fi
#enable AmbaMqueue daemon
if [ -x /usr/bin/amba_mq_handler ]; then
amba_mq_handler
fi
#enable lnxfio_stream daemon
if [ -x /usr/bin/lu_lnxfio_stream ]; then
nice -n -20 /usr/bin/lu_lnxfio_stream
fi
#enable amba_qrconfig daemon
if [ -x /usr/bin/amba_qrconfig ]; then
fi
#for bootup speed, some modules are preloaded before hibernate
if [ -x /usr/local/share/script/preload.sh ]; then
fi
if [ -x /usr/local/share/script/bt_preload.sh ]; then
fi
#for ar6004 WoWLAN
mount -t debugfs none /sys/kernel/debug/
#Apply TCP tuning parameters
if [ -x /usr/local/share/script/tcp_script.sh ]; then
The russians are having fun with it, there's a RAW shooting script I can't download for some reason
Nutsey - what's the script for auto raw capture?
And anyone know which raw decoder works for these ambarella raw files?
I also saw a HDR script on the russian site but could not download it.. anyone been able to download the attachments from that forum?
Check the nickname of the guy who posts scripts there ))any russian friend here? for downloading the scripts?
Okay, thanks!Check the nickname of the guy who posts scripts there ))
Use raw2dng tool to convert RAW files to Adobe DNG format. Drag&drop RAW files to its window.
Here is HDR script. It generates 6 JPEG files with various shutter and ISO fixed to 100. Join them to HDR in any suitable soft.
It describes format of our RAW file (frame size, bayer byte order etc.), nothing really to adjust there.nutsey, what is the meaning of the parameter in "raw2nef.ini" configuration file? Can I adjust it?
Hi! "sleep 0.x" works fine and there is a usleep command in ms
No, it doesn't from an autoexec script.
#convert sleep to milliseconds hack
writew 0xC0155712 0x0000
#beep and blink front LED
#LEDs
#12 shutter
#114 WIFI
#6 front blue
#54 front red
sleep 100 <---- here run as Second, not Milisecond.
t gpio 6 sw out0
t gpio 54 sw out1
sleep 1
