Xiaomi Yi firmware mirror site & archive - 1.2.13 (and older)
you obviously missed the point of my mirror site ;)
no new firmware on the xiao site yet.
there was no such firmware, however i am currently downloading (trying to) 1.2. 10 so it could be put on the mirror site.
these are non-released internal beta versions.
1.2.10 manual for Z22 : Bug! (Problem On-Off, Drop YiCam is turned Off instantly, charged not functionnaly...) Not Stable :(
test re-download firmware, battery charged, changed sd-card... 1.2.10 not very good for Z22!
Test install 1.3.0 beta for my Z22 : works and not problem!!
And You ? Problem Z22 and 1.2.10 ?
1.3.0 is higher betta ))
1.2.10 is higher release than 1.2.7.13, it contains changes in 1.2.7.13 as well.
1.2.7.13 have 2304 resolution
1.2.10 have nothing interesting ))
or
1.0.12 and lower have non droped bitrate after restart record... newer firmware ( pri partition) drop high bitrate .
Same experience for me. Z22 with 1.2.10. Camera on & dropped on carpeted floor from about a foot off the floor. The camera turned off instantly. Maybe the battery lost contact? And, is this a problem?
1.2.10 have nothing intresting ))
Earlier versions (maybe pre-1.20) of the firmware included the 2304 res, but, if you chose it, you'd get an error message that it was not available (or words to that effect). Anyway, it never worked when it was in the firmware.
non-public firmware on unofficial page.. how secure is that :)
The xiaoyi site is the official public source... The Google+ group is the beta tester channel...
In fact if you come in the Google+ group, you can download the beta version of the app from Google Play... This would be impossible if the group wasn't official..
@Andy_S do you have fw 1.0.0 for 22L???
i have problem the SN in FW and behind baterai is different.
and if i use it for a few minutes suddenly brick then soundly beep beep make me crazy.
if my xiaoyi can run normally, i will donate.
11226946_728162823962806_967808590610920923_o.jpg 11880215_728206323958456_929333165_n.jpg
AFAIK there was no 1.0.0 for L models. And all i have is on the mirror site...
This is very strange, if i were you, i would use the "ELF debrick" trick and hardflash the Z22L firmware (if you are not able to flash the L version directly).
Ofc. only if you are 100% sure you have L version, which - according to your sticker - you do.
PS: i also checked the barcode against the printed serial, it is a match...
i already do flash using directusb ambarella then elf brick like cruz post.
i download file elf fw 1.2.6 22L in cruz's post but i get sn 22.
i think it's wrong file.
do you have file elf for 22L?
