Xiaomi Yi Sports Camera - Custom Firmware (Base 1.0.7) - Bitrate Increased to 30Mbps all modes
hello,
could anyone post 2.3k 50-60 mbit address please
35 has a lot of compression artifacts when lot of scene is moving
thank you
can someone upload a custom 30/35mbit for the z22L with 1.2.6 or will it be 1.2.10 ? Do you have to make a new custom firmware every time Xiaomi makes a new one? don't need 2k ..1080p 60fps 30mbit is more than enough.
Use autoexec.ash to do that, very simple!
I don't understand if is possibile to unlock 2k 35mbps with custom firmware instead using script, cause I still don't understand how merge more scripts together so if I could do that with custom firmware my problems with scripts are a little less complicated... :)
Tried, but can't find any download. I'm very noob at this. can't find anything. so if anyone here that knows exatly how to get a functional yi with 1080p 60fps 35mbit for z22L with 1.2.6 firmware in great detail I would appreciate it bigtime. tried to make a custom firmware but the download link on thew aft / ambarella site is just a text file with a bunch of codes :/
The firmware already has everything you're looking for except not at 35Mbps. You can get what you want with the attached script, compliments of funnel, one of our users. Download, unzip, and place the file that's in the folder, named autoexec.ash, in the root directory of the microSD card you will use to boot your camera. After you've done that, start the camera, shoot a test video and check it. I suggest that you should not open and resave the file, unless you are certain that your text editor produces Unix line endings, a necessity for the camera to recognize the file. Without the proper line endings, the script will not work. There can be only one autoexec.ash file on a card, so if you already are using another one, you can append this bit of code to it. Scripts are only temporary - not permanent alterations. In order to work, they must be on the card you intend to use when you start the camera.
Funnel has a lot of very useful scripts locate at his GitHub repository:
https://github.com/funneld/XiaomiYi/tree/master/autoexec.ash
Another helpful user is Nutsey...
http://nutseynuts.blogspot.com/2015/06/xiaomi-yi-action-cam-custom-scripts.html
The link of aft firmware editor is this http://dc.p-mc.eu/a7tool/AFT132.jar
it's a jar file, you need lastest java installed on your pc.
This afternoon if you want I'll upload the custom firmware for your version. Now I'm not at home.
Sharing a video with you guys:
BTW anyone want to be inner tester of xiaoyi company? Just test the firmware beta version before release and report any problems. I already uploaded 1.3.0 firmware to my facebook group so if you guys interested just join: https://www.facebook.com/groups/838989242858914/
I see the result, but I miss "how to" ... :D
Anyway nice effect....
-- Latest Firmware Version:v1.2.10 --
  • Added the camera information into video
  • Optimized the wifi module to improve the stability of the wifi connection with iphone
  • Optimized the communication between app and camera , in order to prevent the camera from command blocking
  • Improved the connection smooth while lapse photography
  • Fixed the crash while power up the camera
  • Fixed unable to light the wifi hint light
  • Fixed unable to stop alerting of buzzer while finding the camera.
  • Fixed the anomalies coursed by taking photo via app, while finding the camera
Hey, does any one have a modified v1.2.10 fw bitrate hack up yet? thanks
Found how to do it, for this sort of effect it's a bit expensive for me ... :p
HI.
please can someone make (1080p 60fps and 720p 120 fps both to 35Mbps) for Z221 :)
